    [SOLVED]accessing scene transitions
    8 Posts 4 Posters 975 Views 4 Watching
    • P
      Pout
      In view menu-->Animation-->Settings it is possible to enable/disable scene transistions.
      Can this function be accessed by ruby?
      Thx!
      • thomthomT
        Sketchup.active_model.options.keys.each {|key| p key; Sketchup.active_model.options[key].each {|k,v| puts "> #{k} - #{v}"} }
        This returns all the model options you have access to:
        ` "PageOptions"
        ShowTransition - false
        TransitionTime - 2.0
        "SlideshowOptions"
        LoopSlideshow - true
        SlideTime - 1.0
        "NamedOptions"
        "UnitsOptions"
        LengthPrecision - 0
        LengthFormat - 0
        LengthUnit - 2
        LengthSnapEnabled - false
        LengthSnapLength - 0.0393700787401575
        AnglePrecision - 1
        AngleSnapEnabled - true
        SnapAngle - 15.0
        SuppressUnitsDisplay - false
        ForceInchDisplay - false
        "PrintOptions"
        PrintWidth - 7.0
        PrintHeight - 5.0
        ComputeSizeFromScale - false
        SizeInPrint - 1.0
        SizeInModel - 3.225830078125
        VectorMode - false
        FitToPage - true
        NumberOfPages - 1
        LineWeight - 0.5
        PixelsPerInch - 150.0
        SectionSlice - false
        ModelExtents - false
        PrintQuality - 3
        ScaleAdjustment - 1.0
        QualityAdjustment - 0.5`
        So you want: Sketchup.active_model.options['PageOptions']['TransitionTime']
        • thomthomT
          @pout said:
          For those interested can be set with:
          Sketchup.active_model.options[0][0]='false' or 'true'
          That is not a reliable way to set the options. Use the string keys. The numeric index differ from version to version.
          • P
            Pout
            thx again, I edited my text.
            • P
              Pout
              huuray for ThomThom!
              thx!
              • thomthomT
                'false' won't work as it'll evaluate to true.
                Only false and nil evaluate to false.
                • J
                  Jim
                  And 'true' and 'false' are Strings, and although they may work, the proper values are boolean true and false.
                  Sketchup.active_model.options["PageOptions"]["ShowTransition"] = true
                  (Fixed options key name from TransitionTime to ShowTransition)
                  • AdamBA
                    AdamB
                    Is it a known bug that
                    Sketchup.active_model.options["SlideshowOptions"]["LoopSlideshow"]
                    appears to be totally ignored by SketchUp?
                    I've checked back to SU6 and it is read/writable but the animation still loops if its set to false
