    Does "Materials" have two meanings?
    3 Posts 2 Posters 1.8k Views 2 Watching
    • M
      mfseeker
      I think I have discovered a confusion that may hide a very useful feature. The word "Material" seems to have two different meanings. If I go to Component Attributes and define a Material attribute for a component, say Material = Maple, I can use that attribute elsewhere. In Cutlist, for example, I can get a list of all my "Maple" components. Then if I go to Sketchup's Materials window and select a material color, say 0128_White, I can paint my maple component with white. If I do that, when I check the Material attribute with Component Attributes, it is still Maple. That's great! It's exactly what I wanted to do. I have a model with several physically different materials, some boards, some plywood, some MDF, etc. I want them all painted the same color without losing their underlying materials.
      In addition, if I open one of my white maple components for editing and choose Reverse Faces, the chosen face shows the Maple color.
      Are there two different kind of "Material" such that one of each kind can be applied to a component, or, as seems more likely, can any one material be applied to the component as a whole, while a second material of any kind can be applied to any or all of the faces of the component without interfering with the underlying component material?
      Has this feature been clearly documented somewhere that I have missed? Is there some plan to remove the ambiguity in the word "Material" as it is used in Sketchup?
      mfseeker
        Are you seeing this with Dynamic Components?
        • M
          mfseeker
          Yes. both dynamic and static.
