    Points equal but distance is not larger or less?
    3 Posts 2 Posters 414 Views 2 Watching
      ` pt1 = Geom::Point3d.new(-1473.34, -1459.58, 803.961)
      pt3 = Geom::Point3d.new(-1473.34, -1459.58, 803.96)
      pt1 == pt3
      true
      pt1.distance(pt3)
      0.000999999999976353
      pt1.distance(pt3) > 0.001
      false
      pt1.distance(pt3) < 0.001
      false`
        Ah! Because it was comparing Length classes - which has SU's tolerance builtin.
        This works as expected:
        pt1.distance(pt3).to_f < 0.001 true pt1.distance(pt3).to_f > 0.001 false
        I wanted to compare to point with a higher tolerance than SU's tolerance.
        So either I must convert to float - yet another operation, or I do:
        pt1.distance(pt3) <= 0.002
        • AdamBA Offline
          AdamB
          Sure you know this, but if you're comparing distances rather than interested in the absolute distance, the fastest way will be to project a vector onto itself using scalar product.
          p1.dot(p1) < p2.dot(p2)
          Adam
