    Question: Folding Shutter in SketchyPhysics
    4 Posts 3 Posters 555 Views 3 Watching
    • H
      harnstein
      Good morning sketchucation!
      Once more i hope you can help me out.
      For testing an option for a facade i'd like to place some shutters all around the building- and then see how it changes the shape when i move the sliders.
      Now, my problem is, that (as you may see in my attached file)
      1. hinge is fixed, so how to get it moving with the shutter
      2. i don't know how to set it all up correctly or which tools i should use to make it slide on a track so that it folds up or closes the window.
      3. place this object in a model and a scene and not everything falling down to nowhere.. 😉 (maybe this is not possible..)
      I hope you understand what i mean- thanks in advance-
      _h
      folding shutter.skp
      still sketchin'
      • mitcorbM
        mitcorb
        Are you aware that there is a Sketchyphysics Forum/ Blog which is not part of Sketchucation, where you may be able to get many of your questions answered?
        Also, I think there is a specific subforum here that can direct you to that other one.
        I am having trouble with staying logged in, so I can't go shopping for the links to provide them here.
        • H
          harnstein
          Thanks!
          I know that there is this sketchyphysics blog and that they have a forum, too- i thought here more people would see it..
          But you're also right that there is a special place within this forum, i didn't know that before- it's a sub-section in the extension folder.
          So i'll post it there- thanks again.
          May a mod please delete this on? Thanks.
          still sketchin'
          • J
            Jim
            This can be done with a Dynamic Component also. Then the user of the component would not need to have SP installed to manipulate the door.
            Here is an example posted in the DC Forum:
            http://forums.sketchucation.com/viewtopic.php?f=289&t=16332
