    Truss cottage
    18 Posts 10 Posters 1.5k Views 10 Watching
      ScottPara
      This is a personal project and was inspired by an image I had seen. All modeling was done in Sketchup with some pre-built components as well. Rendering was in Twilight. Comments welcome.
      Scott
      Love the fact that some HATE my avatar.....
      • Mike LuceyM Offline
        Mike Lucey
        Hi Scott,
        Looks very realistic. The only thing I don't like are the black joints on the flooring. Would the joints actually be that wide?
        Mike
          ScottPara
          It is white washed reclaimed flooring. I know it is wider than typical flooring but I think part of it is my texture as well. I am going to build a better texture/bump map and run it again.
          Thanks,
          Scott
          • pugz1983P Offline
            pugz1983
            Hi Scott,
            Nice render and nice model. First I thougt you modelled the floor, but you mentioned it is a texture map. The bolts in the wooden beams catch my attention. I know they should be there, but maybe there are to many. You could use a wooden pen construction. I also think that the render would be better if rendered with another render application. Twillight just doesn't do photorealistic rendering as wel as a few other apps like Indigo, Fry , Max or Vray. I looked at the showcase on the twillight homepage, but there aren't many renders that blow me away in terms of realisme.
            Greetz Twan
              ScottPara
              Twan,
              Thanks for your comments. As far as the bolts they were matched to the photo for placement and count.
              I have fryrender, vray and MAX but I choose Twilight for its speed and ease of use. I have 10-12 house in the toal project and that includes modeling and rendering so for me Twilight is fast. Vray may be better in terms of overall quality but setup sucks and lighting can take a while unless you are just going to go for GI alone. Twilight is also FAR cheaper than any other you noted and is well integrated into Sketchup.
              Best regards,
              Scott
              • jo-keJ Offline
                jo-ke
                I like that one very much, especially the curtains.
                http://www.zz7.de
                • olisheaO Offline
                  olishea
                  thats a winner! πŸ‘ πŸ˜„ background image well integrated too, nice one!
                  WIth regards to bolts, isn't there a gang nail plate you can use instead? can't remember the exact term for it.
                  twan: have you not seen the twilight showcase? they look pretty real to me!
                  http://twilightrender.com/phpBB3/viewtopic.php?f=14&t=714
                  oli
                  • FrederikF Offline
                    Frederik
                    Really great looking render, Scott...
                    http://www.kerkythea.net/users/Frederik/Anim-Icons/clap-above.gif
                    Ooohhh... You forgot to mention the new Thea Render... πŸ˜‰
                    I'm amazed that you're comparing applications this way, Twan... πŸ˜•
                    Is the integration and userfriendlyness as good as Twilight for any of the applications you've mentioned...??
                    And what about the price...??
                    Happy to hear that you've found some - at least...
                    I've also seen renders made with the above mentioned render applications that looked far from photorealistic...
                    I believe this is saying more about the "driver" and not the application itself... πŸ˜‰
                    Cheers
                    Kim Frederik
                    • daleD Offline
                      dale
                      I find this really appealing Scott. I suppose the floor could use a tweak, but pretty powerful image.
                      Although I'm not sure I'd be allowed in a room that white though πŸ˜„
                      As for Twilight, I've been really impressed with some of the work I have seen. If there was a mac version, It would be in my repertoire.
                      Some of the twilight materials and images rendered in some of the challenges here have been stellar.
                      And did I mention price as well?
                      • pugz1983P Offline
                        pugz1983
                        Hi Scott,
                        I know that I was comparing apples with pears. Don't get me wrong, The render is great, and Twillight is very good because of the integration in SU and price. But I think the render could be even beter If rendered with another application.
                        Oli, I've checked the showcase on the Twillight site again. There are only a few masterpieces I think. Its hard to put my finger on it, but I think it has to do with the realism of the materials or lighting.
                        Greetz Twan
                        • olisheaO Offline
                          olishea
                          I agree with Frederik:
                          Some twilight images I've made even fool me....and I've worked on them!
                          If scott let this render cook longer, with no noise, I really cannot see how vray could make it any better. Many vray renders are so glossy and colourful they just look wrong. and the price 😲 😲 😲
                          oli
                          • BoxB Offline
                            I've not done any rendering yet but what I see astounds me.
                            My wish would be that people post an image of the model as well so you can see a bit of where the render came from.
                              ScottPara
                              Here you go. Hope this helps.
                              Scott
                              • BoxB Offline
                                Thanks for that Scott, it certainly helps get my head around it a little better.
                                • david_hD Offline
                                  david_h
                                  Yeah. . .I'd rethink the bolts. . .paint 'em white. they'll just disappear.
                                  Awesome render. THought it was a photo at first. πŸ‘
                                    ScottPara
                                    Thanks Dave.
                                    As for the bolts they match the photo I modeled to, I kind of like them.
                                    Scott
                                    • david_hD Offline
                                      david_h
                                      sure . ..whatever floats your boat.
                                      It's all just a preference thing.
                                      D πŸ’š
                                      • F Offline
                                        fymoro
                                        I like the mood of your renders... πŸ‘ Congrats... πŸ˜‰
                                        Wait for some update...
                                        http://www.thearender.com/cms/index.php/news/featured-artists/137-frederic-yves-moro.html
