    Defining Length, Width and Thickness
    10 Posts 3 Posters 1.2k Views 3 Watching
      dedmin
      I'm trying to define 3 component attributes - Length, Width and Thickness
      Length - the biggest of LenX, LenY and LenZ
      Width - the middle
      Thickness - the smallest value of the LenX, LenY and LenZ
      Any ideas? Thanks.
        Jim
        I think this will work.
        Edit - No! it won't work!
          Jim
          No, that's doesn't always work.
          I guess the answer is in IF statements.
            dedmin
            I didn't saw this functions in the Help!? ๐Ÿ˜ฎ
              Jim
              Here is a list of functions:
              Error 404 (Not Found)!!1
              (sketchup.google.com)
              and here is a function reference:
                cjthompson
                I haven't worked with Dynamic components much, and only have the free version, but wouldn't something like this work?
                =smallest(largest(LenX,LenY),largest(LenY,LenZ),largest(LenX,LenZ))
                  dedmin
                  ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘
                    Jim
                    Yep, good one. ๐Ÿ‘
                      dedmin
                      Here we go:
                      The problem is that this responses only using SketchUP's scale tool - with FredoScale and FredoStrech the LenX,Y,Z changes but not Length, Width and Thickness ๐Ÿ˜‰ And is there a way to order all this attributes? Thanks for the help!
                        dedmin
                        To update the changes - right click - Redraw! To sort the attributes as You like just put the alphabets in front:
