Plugin-CurviShear پلاگین کروی-شی-یر
CurviShear
این یه پلاگین منفرد و کوچولو واسه تغییرشکل دادن به منحنیها یه یه مجموعه منحنی واسه برش عمودی دادن به اونهاس در امتداد مسیرشون، لذا ازون واسه ساخت رمپها میشه استفاده کردیه بحث جالب درین مورد اینجا هست
[/color] (see http://forums.sketchucation.com/viewtopic.php?f=15&t=29102#p253279)[attachment=2:1xjulaw1]<!-- ia2 -->CurviShear illustration.png<!-- ia2 -->[/attachment:1xjulaw1]
CurviShear – 25 Jun 10 - 22:30 CET
[attachment=0:1xjulaw1]<!-- ia0 -->CurviShear.rb<!-- ia0 -->[/attachment:1xjulaw1]
IMPORTANTاین پلاگین به نصب "لیب فردو06 نیازی ندارهNo user manual (see section Quick Startbelow)
- Language: English and French
- Menus: by default, it is installed in Plugins > Curve Shearing and also appears in the Contextual menu when there is at least one curve in the current selection
- Icon toolbar: No icon provided
- The plugin is free, for private and commercial usage.
Just Download and drop the attached CurviShear.rb file into the SU Plugins directory
On Mac the SU plugin directory should be:
Macintosh HD/Library/Application Support/Google SketchUp 7/SketchUp/pluginsOverview
More video to come. Here is a quick one
[attachment=1:1xjulaw1]<!-- ia1 -->Ramp Shearing.gif<!-- ia1 -->[/attachment:1xjulaw1]-
Select one or several curves
Call the Plugin on the selection (main menu or contextual menu “Curve Shearing”)
The dialog box appears:
[attachment=3:1xjulaw1]<!-- ia3 -->CurviShear dialog.png<!-- ia3 -->[/attachment:1xjulaw1] -
Set the base height, the maximum height (from the base height). Can be positive or negative.
The extremities of the curves which will be the most elevated are highlighted. If you prefer the other ends, then toggle the Reverse flag in the combo box
You have an option to generate the ramp within a group.
Parameters are kept within the Sketchup session (but not across sessions)
The new curves are then generated and you exit the plugin
From there you may want to put a skin on the ramp (with Curviloft or TIG’s extrude tools)
IMPORTANT: For the time being, the Direction for Shearing is the Z AXIS. So your curves should preferrably be in the Horizontal plane.
CurviShear 1.0b - 25 Jun 10 - 22:30 CET: fixed problem of main menu
CurviShear 1.0a - 25 Jun 10 - 19:00 CET: First versionIMPORTANT: Please note that Curviloft is still in Beta and may not be able to generate the skinning of the ramps.
برای دانلود و دیدن کل بحث به این آدرس مراجعه کنید:
http://forums.sketchucation.com/viewtopic.php?f=323&t=29230 -
سلام
میشه لطف کنید بگید این حجم رو با چه پلاگین یا روشی بدون پلاگین میتونم ایجاد کنم.متشک -
محسن جان ممکنه یه بار دیگه تصویر مورد نظرت رو ضمیمه کنی به پستت؟
Register LoginAdvertisement
