    Plugin-CurviShear پلاگین کروی-شی-یر
    Scheduled Pinned Locked Moved فارسی
    3 Posts 2 Posters 8.7k Views 2 Watching
    • majidM Offline
      majid
      http://forums.sketchucation.com/download/file.php?id=49290
      CurviShear
      این یه پلاگین منفرد و کوچولو واسه تغییرشکل دادن به منحنیها یه یه مجموعه منحنی واسه برش عمودی دادن به اونهاس در امتداد مسیرشون، لذا ازون واسه ساخت رمپها میشه استفاده کرد
      یه بحث جالب درین مورد اینجا هست
      [/color] (see http://forums.sketchucation.com/viewtopic.php?f=15&t=29102#p253279)
      [attachment=2:1xjulaw1]<!-- ia2 -->CurviShear illustration.png<!-- ia2 -->[/attachment:1xjulaw1]
      http://forums.sketchucation.com/download/file.php?id=49285
      CurviShear – 25 Jun 10 - 22:30 CET
      [attachment=0:1xjulaw1]<!-- ia0 -->CurviShear.rb<!-- ia0 -->[/attachment:1xjulaw1]
      IMPORTANTاین پلاگین به نصب "لیب فردو06 نیازی نداره
      http://forums.sketchucation.com/download/file.php?id=49286
      No user manual (see section Quick Startbelow)
      • Language: English and French
      • Menus: by default, it is installed in Plugins > Curve Shearing and also appears in the Contextual menu when there is at least one curve in the current selection
      • Icon toolbar: No icon provided
      • The plugin is free, for private and commercial usage.
      http://forums.sketchucation.com/download/file.php?id=49287
      Just Download and drop the attached CurviShear.rb file into the SU Plugins directory
      On Mac the SU plugin directory should be:
      Macintosh HD/Library/Application Support/Google SketchUp 7/SketchUp/plugins
      http://forums.sketchucation.com/download/file.php?id=49284
      Overview
      More video to come. Here is a quick one
      [attachment=1:1xjulaw1]<!-- ia1 -->Ramp Shearing.gif<!-- ia1 -->[/attachment:1xjulaw1]
      http://forums.sketchucation.com/download/file.php?id=49288
      • Select one or several curves
      • Call the Plugin on the selection (main menu or contextual menu “Curve Shearing”)
      • The dialog box appears:
        [attachment=3:1xjulaw1]<!-- ia3 -->CurviShear dialog.png<!-- ia3 -->[/attachment:1xjulaw1]
      • Set the base height, the maximum height (from the base height). Can be positive or negative.
      • The extremities of the curves which will be the most elevated are highlighted. If you prefer the other ends, then toggle the Reverse flag in the combo box
      • You have an option to generate the ramp within a group.
      • Parameters are kept within the Sketchup session (but not across sessions)
      • The new curves are then generated and you exit the plugin
      • From there you may want to put a skin on the ramp (with Curviloft or TIG’s extrude tools)
      IMPORTANT: For the time being, the Direction for Shearing is the Z AXIS. So your curves should preferrably be in the Horizontal plane.
      http://forums.sketchucation.com/download/file.php?id=49289
      CurviShear 1.0b - 25 Jun 10 - 22:30 CET: fixed problem of main menu
      CurviShear 1.0a - 25 Jun 10 - 19:00 CET: First version
      IMPORTANT: Please note that Curviloft is still in Beta and may not be able to generate the skinning of the ramps.
      برای دانلود و دیدن کل بحث به این آدرس مراجعه کنید:
      http://forums.sketchucation.com/viewtopic.php?f=323&t=29230
        mohsen
        سلام
        میشه لطف کنید بگید این حجم رو با چه پلاگین یا روشی بدون پلاگین میتونم ایجاد کنم.متشک
        • majidM Offline
          majid
          محسن جان ممکنه یه بار دیگه تصویر مورد نظرت رو ضمیمه کنی به پستت؟
