    Plugin for .igs or .iges files
    7 Posts 5 Posters 5.1k Views 5 Watching
      ahandrew
      I am trying to find a SU plugin that will read in a .igs or .iges file.
      • Chris FullmerC Offline
        What are those file types for?
        All my Plugins I've written
          ahandrew
          .igs or .iges are International Graphics Exchange Specification which is the generic standard for 2D and 3D graphics. A file in the IGES format should be able to be read by any 2D or 3D CAD program. While I understand SU is not technically a CAD program, it is being used as and touted to be able to work as one. However, it does not read .igs or .iges file formats. I would hope someone out there has done a Ruby script or some other program to pull that format into SU.
          • honoluludesktopH Offline
            honoluludesktop
            SU will do skp2dxf, then you require a 3d party converter for dxf2igs. If you "google" the second, you will find translators.
            • DareDevilD Offline
              DareDevil
              If I'm right, ahandrew wants to import IGES in SU, not export...
              SU and IGES are'nt in the same 3D world... 😉
              Iges can discribe nurbs, cuves and other 3D free forms, and SU only knows polygons. Importing IGES file means solving all free surfaces to polygons 😞
              I use to manipulate this kind of files and I use MoI3D as portal between these two worlds.
                ahandrew
                Thanks for all the help.
                I found a plugin that will import (or export) .igs (.iges) files located at http://www.sycode.com/products. The plugin costs $95 ($125 with update service) for import and the same for export. It seems to work pretty well. There is a trial version that I downloaded and ran some .igs files through. It seemed to do quite well.
                PS: I am new a SketchUcation. How do I stop or delete a topic in the forum?
                  You can delete your last post of a thread if there is not yet reply
                  you can write [Resolved] on the title subject but your subject is always open
                  For the rest send a PM to a moderator or administrator
