    How to input a time ?
    15 Posts 4 Posters 2.1k Views 4 Watching
    • P
      pvbuero
      Hello,
      I' d like to input a time into my script formated as it's made in the shadowinfo dialog in SU. Is there a way to configure the inputbox to achieve that or how can I make such a dialog ?
      Thanks for your help
      Matthias
      • thomthomT
        You'd have to make a webdialog. I'd recommend using a framework, like jQuery that make thing much easier. jQuery has UI plugin widgets that let you easily add the UI gadgets you need.
        • Dan RathbunD
          Dan Rathbun
          @pvbuero said:
          I'd like to input a time into my script formated as it's made in the shadowinfo dialog in SU.
          Interesting! I just noticed that you have your time set to display the 24 hour clock.
          I cannot find and way thru the SU API of determining whether the user wants AM/PM clock or 24 hour clock.
          I'm not here much anymore.
          • thomthomT
            I guess it's taken from the system locale?
            • Dan RathbunD
              Dan Rathbun
              @pvbuero said:
              I'd like to input a time into my script formatted as it's made in the shadowinfo dialog in SU.
              [floatl:12wnmvbs][/floatl:12wnmvbs][floatl:12wnmvbs][/floatl:12wnmvbs][floatl:12wnmvbs][/floatl:12wnmvbs][floatl:12wnmvbs][/floatl:12wnmvbs][floatl:12wnmvbs][/floatl:12wnmvbs]
              http://forums.sketchucation.com/download/file.php?id=50453
              [floatl:12wnmvbs][/floatl:12wnmvbs][floatl:12wnmvbs][/floatl:12wnmvbs][floatl:12wnmvbs][/floatl:12wnmvbs][floatl:12wnmvbs][/floatl:12wnmvbs][floatl:12wnmvbs][/floatl:12wnmvbs]Schatten.png
              If your asking about slider, textbox and spinner controls all linked together, then ThomThom is correct. You either must make a WebDialog, or use wxSU (wxWidgets,) but going the wx route requires your users to have wxSU installed. (I'm also not sure if wx works well on the Mac.)
              • P
                pvbuero
                Hi Dan,
                thank's a lot for your help.
                I think that's because I use the german SU Version and we usually use a 24 hour clock here.
                I 'll try to understand your code as an exercise but I' ve already begun to read the webdialogs chapter in Automatic SketchUp... I'm curious where that leads me to. πŸ˜•
                Matthias
                • Dan RathbunD
                  Dan Rathbun
                  @pvbuero said:
                  I've already begun to read the webdialogs chapter in Automatic SketchUp... I'm curious where that leads me to. πŸ˜•
                  Don't forget ThomThom's WebDialogs - The Lost Manual topic
                  .... or download the The PDF version.
                  • P
                    pvbuero
                    Sigh... I now know how sketchup functions can be called by a webdialog. I played a little with the example in chapter 13 of automatic sketchup...
                    But now back to my objective: I simply want to input a time with a webdialog. I googled timepicker jquery and found that.
                    But I've no idea how I can use that tool. Where to find the variable with the time ? where must the "window.location = 'skp:...." command be placed ? ...
                    Seems to me I have to learn jquery first, but therefore I need to learn javascript first 😞
                    Well .. I didn't want to learn all languages available, I just want to input a time (and learn ruby for sketchup πŸ˜„ )
                    Is there a little tutorial or something to make the first step using jquery UI plugins a litte easier ?
                    As always .. thanks a lot for your help.
                    Matthias
                    • Chris FullmerC
                      Maybe I give up too easily, but I've completely quit trying to use web dialogs. It seems the pro's have big headaches trying to implement them smoothly. So a beginner like doesn't stand a chance. It was VERY overwhelming to try to learn HTML, javascript, and css all at once. Then people keep mentiong jquery and these other development packages to use. That is just another layer of complexity that make webdialogs very innaccesible for a beginner.
                      I've had quite a few scripts have to be more simple in scope because I couldn't make a user interface for them. I've recently found some great workarounds using the view.draw commands. But they are still not quite as versatil as they could be for UI making. And the WxSU package still seems to be buggy, and requires a separate installtion by the user. So its a good alternative, but not really great.
                      So as painful as it may be, you might just consider forcing the user input to be done through the built in SU input window.
                      Chris
                      All my Plugins I've written
                      • Dan RathbunD
                        Dan Rathbun
                        @pvbuero said:
                        Is there a way to configure the inputbox to achieve that ...
                        I think you are refering to UI.inputbox() and it's nasty habit of not not allowing anything other than a decimal point mixed with numerals.
                        But you could use a string. And then parse the string afterward.
                        @hour=13
                        @min=30
                        @timeStr=@hour.to_s<<';'<<@min.to_s
                        getTime=true
                        if getTime
                          result = UI.inputbox(['Time'],[@timeStr],'enter Time')
                          #result = UI.inputbox(['Time'],[@timeStr],'eintreten Uhrzeit')
                          unless result.false?
                            if result.include?(';')
                              @hour=result[0].split(';')[0].to_i # stunde/uhr
                              @min=result[0].split(';')[1].to_i  # winzig
                            if @hour.between?(0,23) && @min.between?(0,59)
                                getTime=false
                            if getTime
                              # invalid time string
                              ret = UI.messagebox('Invalid Time !',MB_RETRYCANCEL)
                              #ret = UI.messagebox('Invalide Uhrzeit !',MB_RETRYCANCEL)
                              getTime=false unless ret==4
                          else
                            # user cancelled the dialog
                            getTime=false
                          retry if getTime
                        end #mod
                        end #mod
                        • Dan RathbunD
                          Dan Rathbun
                              def get_shadow_time
                                model = Sketchup.active_model
                                shadowinfo = model.shadow_info
                                shadtime = shadowinfo['ShadowTime']
                                # shadtime is a Time class object
                          • Ruby Time class from the 'Pick-Axe' book.
                          • Time class in Ruby Core Docs.
                          • Dan RathbunD
                            Dan Rathbun
                            @pvbuero said:
                            I didn't want to learn all languages available, I just want to input a time (and learn ruby for sketchup ... )
                            You never were clear on whether it was sliders and spinner controls that you desired, or just a plain ol' entry box. ??
                            Did you try the example I posted above? (It does need to be adjusted for the bug in the Shadow Time returned by Sketchup. And I didn't test it.)
                            EDIT: I did fix an error (because the inputbox returns false if the user cancels,) I changed:
                            unless result.nil?
                            to:
                            • thomthomT
                              Yes, one do need to understand tha basics of HTML and javacscript before taking on a framework that builds upon it.
                              What is your task? A window with a slider where you can define a time of the day?
                              • P
                                pvbuero
                                had to pause a little with ruby and watch the soccer match πŸ˜‰
                                It not necessarily needs to be a slider. I do this little project just for fun and to learn how to use ruby.
                                As I'm always nosy for new things I wanted to know how user interfaces can be made in SU.
                                Now I know something about the different approaches and I also know that it takes a lot more effort to understand and use webdialogs than just configuring little predefined parts...
                                For now I'm satisfied with Dan's script. Thank you for that...
                                Matthias
                                • P
                                  pvbuero
                                  @dan rathbun said:
                                      def get_shadow_time
                                  >     end
                                  I didn't mean in SU. I meant "variable with the time" in the javascript file ...
                                  But I think that's to much new stuff at once.
