    Posting tables of data in the forum
    11 Posts 3 Posters 1.6k Views 3 Watching
    • Dan RathbunD Offline
      Dan Rathbun
      Finally figured out how to post tables, on this forum. Comes in handy for listing arguments and so forth.
      So I thot' I'd share.
      To post tables of data, use the (floatl) tag, and type the table in columns.
      This is a BBcode table:
      [floatl:glq9ab7r]num
      3[/floatl:glq9ab7r][floatl:glq9ab7r]value
      1.2
      8
      'Hi'[/floatl:glq9ab7r][floatl:glq9ab7r]type
      float
      int
      string[/floatl:glq9ab7r][floatl:glq9ab7r]Note:(heading row)
      This is the first row
      And of course the second row
      Followed by the last row[/floatl:glq9ab7r]
      ... is typed like this:
      [floatl][u]num[/u]
      3[/floatl][floatl][u]value[/u]
      1.2
      8
      'Hi'[/floatl][floatl][u]type[/u]
      float
      int
      string[/floatl][floatl][u]Note[/u];(heading row)
      Followed by the last row[/floatl]
      If text is follow the table, there must be tablerows+1 linefeeds before the text, so it gets pushed down below the table.
      If you wish monospaced text, wrap the table code in a (ruby) tag. If you wish both monospaced and a certain color, wrap it in a (color) tag first, then wrap in a (ruby) tag.
      A blue monospaced table:
      %(#4000BF)[[floatl:glq9ab7r]num 1 2 3[/floatl:glq9ab7r][floatl:glq9ab7r]value 1.2 8 'Hi'[/floatl:glq9ab7r][floatl:glq9ab7r]type float int string[/floatl:glq9ab7r][floatl:glq9ab7r]Note:(heading row) This is the first row And of course the second row Followed by the last row[/floatl:glq9ab7r]]
      I'm not here much anymore.
        Jim
        The forum actually supports real tables, although it is easy to get lost in the tags.
        [table=tablebg table1:3f3ppq8p][thead:3f3ppq8p][tr=:3f3ppq8p][th=2:3f3ppq8p]Oh look Ma, I can do tables too![/th:3f3ppq8p][/tr:3f3ppq8p][/thead:3f3ppq8p][tbody:3f3ppq8p][tr=bg1:3f3ppq8p][td=1,:3f3ppq8p]This is the left cell[/td:3f3ppq8p][td=1,:3f3ppq8p]And this (you've guessed it) is the right cell[/td:3f3ppq8p][/tr:3f3ppq8p][tr=bg2:3f3ppq8p][td=1,:3f3ppq8p]This is row[/td:3f3ppq8p][td=1,:3f3ppq8p]This is the second cell of that row.[/td:3f3ppq8p][/tr:3f3ppq8p][/tbody:3f3ppq8p][/table:3f3ppq8p]
        [table=tablebg table1][thead][tr=][th=2]Oh look Ma, I can do tables too![/th][/tr][/thead][tbody][tr=bg1][td=1,]This is the left cell[/td][td=1,]And this (you've guessed it) is the right cell[/td][/tr][tr=bg2][td=1,]This is row[/td][td=1,]This is the second cell of that row.[/td][/tr][/tbody][/table]
        Perhaps a simple forum table generator would make them easier to use.
          Oh - so there are more BBCodes available than those available as buttons? Any list?
            <span class="syntaxdefault"><br />function hello<br /></span><span class="syntaxkeyword">{<br /></span><span class="syntaxdefault">  print </span><span class="syntaxstring">"hello world"<br /></span><span class="syntaxkeyword">}<br /></span><span class="syntaxdefault"> </span>
            def hello
              puts "hello world"
            No Ruby fun - only PHP...
              Dan Rathbun
              Oh! they do work! I tried [table] ... [/table] tags but they just rendered as text. (I didn't use [thead] or [tbody] tags.)
              @jim said:
              ... Perhaps a simple forum table generator would make them easier to use.
              Yes we don't need fancy tables. I'd envisage a popup window with a title box and a grid of textboxes (the 1st being the header row, so draw a <HR> under it.) Then we just type into the cells, and the applet then writes all the tags and such.
              I don't think we need cell column spanning.
              It might be nice to format columns as left just'd text, or right just'd numbers, or centered. (via a control at the top of the data columns.)
                We really should have that for SCF.
                    Dan Rathbun
                    @dan rathbun said:
                    Looks like this phpBB MOD is gonna be orhpaned...
                    The author ("UseLess") saw this post, and refuted my assumption, viz:
                    http://www.phpbbstyles.co.uk[/url:2e64680u] in [url=http://www.phpbbstyles.co.uk/info/viewtopic.php?f=6&t=39&p=360#p362:2e64680u]Re: [MODDB] phpBB Syntax Highlighter - 1.0.12[/url:2e64680u]":2e64680u]
                    No it's not.
                    It [meaning ver 1.0.14 ] just won't be submitted to phpBB for validation.
                    If enough people test the latest version, there's only been 4 downloads of 1.0.14 and not yet of 1.0.14a and report no major problems then it'll be released. But until I get at least some feedback on how it works in various enviroments then it'll stay at DEV status.
                    It might be time to talk to TBD about this issue.
                      Dan Rathbun
                      HOLD the PRESSES!
                      Just checked on GeSHi. The bugs have been fixed in version 1.0.8.8
                      The reason I saw the bugs was that UseLess's test forum, is still running GeSHi version 1.0.8.4 with his Syntax Highlighter.
                      This is a cool test page at GeSHi where you can type code into a textarea in any language and see how it looks after lexing.
                      GeSHi Highlighter Demo page
                        Dan Rathbun
                        BAD NEWS... re, phpBB Syntax Highlighter
                        (1) The MOD author answered me, and confirmed that the HTML NCR bug(s) are caused by GeSHi's Ruby lexer. His suggestion of correcting the bugs on SCF before outputting the webpage is not feasible. (Too many bugs involving '#' characters, and other characters replaced by HTML numeric character references, in both single and double quoted strings.)
                        and worse...
                        (2) He wrote in the MOD discussion forum:
                        phpBB Syntax Highlighter - 1.0.12](http://www.phpbbstyles.co.uk/info/viewtopic.php?f) at phpBBStyles":3lxjk95m]
                        After having read the changes to the mod validation requirements I have decided not to update this mod.
                        Support will be provided for the last release version which is 1.0.12 but 1.0.14 will not be released and will not be submitted for validation by the phpBB MOD Team.
                        Looks like this phpBB MOD is gonna be orhpaned... 😢
                          Dan Rathbun
                          I posted a Ruby Hilited test example(s) at the phpBBStyles forum, ie: Code Test - Ruby
                          EDIT: corrected URL as topic was moved by phpbbstyles moderator.
                          .. in order to see how well the phpBB Syntax Highlighter MOD works/looks.
                          • Adds a BBCode 'syntax' which allows you to post programs / scripts in upto 132 languages and have the post Syntax Highlighted using GeSHi.General description:
                            http://www.phpbb.com/customise/db/mod/syntax_highlighter
                            More info (install notes, etc.):
                            http://www.phpbb.com/community/viewtopic.php?t=1697035#p10232505
                            Extra info:
                            http://www.phpbbstyles.co.uk/info/viewtopic.php?f=6&t=39&p=83
                          Supported coding Syntaxes: [ emphasis on some by me ]
                          Syntax Highlighter - 1.0.8](http://www.phpbbstyles.co.uk/info/viewtopic.php?f)":sk3p0i6l]
                          now supports 138 languages.
                          Supported Syntaxes: abap, actionscript, actionscript3, ada, apache, applescript, apt_sources, asm, asp, autoit, avisynth, bash, basic4gl, bf, bibtex, blitzbasic, bnf, boo, c, c_mac, caddcl, cadlisp, cfdg, cfm, cil, cmake, cobol, cpp, cpp-qt, csharp, css, d, dcs, delphi, diff, div, dos, dot, eiffel, email, erlang, fo, fortran, freebasic, genero, gettext, glsl, gml, gnuplot, groovy, haskell, hq9plus, html4strict, idl, ini, inno, intercal, io, java, java5, javascript, kixtart, klonec, klonecpp, latex, lisp, locobasic, lolcode, lotusformulas, lotusscript, lscript, lsl2, lua, m68k, make, matlab, mirc, modula3, mpasm, mxml, mysql, nsis, oberon2, objc, ocaml, ocaml-brief, oobas, oracle11, oracle8, pascal, per, perl, php, php-brief, phpbb, pic16, pixelbender, plsql, povray, powershell, progress, prolog, properties, providex, python, qbasic, rails, rebol, reg, robots, ruby, sas, scala, scheme, scilab, sdlbasic, smalltalk, smarty, sql, tcl, teraterm, text, thinbasic, tsql, typoscript, vb, vbnet, verilog, vhdl, vim, visualfoxpro, visualprolog, whitespace, whois, winbatch, xhtml, xml, xorg_conf, xpp, z80
                          Using GeSHi version: 1.0.8.4
