    [Plugin]Group in Component
    25 Posts 9 Posters 19.8k Views 9 Watching
    • chriC
      chri
      Hi Giro
      I agree with you , when you tell "... must have been made into a group and then duplicated, before the plugin is used "
      ... but, i don't understand the meaning of "square boxes" and "other types of groups"
      for me, there are only 2 possibilty; a group and non-grouped entities!
      Sincerely
      Chri
      BEFORE.skp
      AFTER.skp
      • G
        glro
        @chri said:
        Hi Giro
        Sincerely
        Chri
        you are right
        i mixed the 2 condition, but only one is true: ""... must have been made into a group and then duplicated, before the plugin is used "
        this is very limitating, though
        I was planning to use this plugin on a sketchup model imported from solidworks using SIMLAB converter
        SIMLAB converts components into groups, and i was planning to use "components.rb" to convert them back to components
        it doesn't work; i shall try to tweak the plugin to make it work, using the position of the bounding box corners
        • chriC
          chri
          Hi Giro
          I have made a test with parts imported from STEP files ( using Moment Of Inspiration ).
          I noticed that when parts contains a lots of entities , it's common to have small differences after import
          Perhaps , you have this kind of problem with your file .
          ... so , the plugin cound not recognize almost similar components .
          Chri
          • G
            glro
            @chri said:
            Hi Giro
            Chri
            interesting
            It might be an explanation, but not in any case
            i make a cube, grouping the faces
            i duplicate it
            i launch the plugin: they are both turned into instances of the same component
            now, i explode them
            turn again each one of them into a group
            and finally i launch the plugin: they are turned into instances of 2 different components
              Hello
              Here a little trick that can help you ๐Ÿ˜‰
              The use of the cool plugin by Thomthom Components Comparison โ˜€
              As there are not yet system of instancied Objects / Group in Moi3D for export to Sketchup we must make a little tricky thing! ๐Ÿ˜„
              Say I have 2 Objects (here a cube duplicated) in Moi3D, I export them in 3DS Format
              Import in Sketchup / Explode one time
              so we have 2 Components triangulated named OBJ1, OBJ2
              Launch the Components Comparaison and Bingo we have now instancied Components! ๐Ÿ˜Ž
              Triangulation can be cleaned by plugin Clean Up by Thomthom again!
              http://s6.postimg.org/ufh8iq7gx/2cubes_de_moi.jpg
              Result will be the same with 2 different cubes but with the sames dimensions! ๐Ÿ˜‰
              http://s6.postimg.org/nqap2pm4x/tictic.jpg
              With more complex objects there is something more to make!
              That is failing or one object is rotated!
              Failed ? ๐Ÿ˜ฎ
              http://s6.postimg.org/dhmtamngx/alas.jpg
              Rotated ? ๐Ÿ˜ฎ
              http://s6.postimg.org/sevabn0pd/tuctuc.jpg
              For resolve this you must just find the good tolerance inside the Thomthom pluging! Don't hesitate to push it! ๐Ÿค“
              Of course many object can be treated in the same time as Shown in this Chri's Video! ๐Ÿ˜‰
              The start Moi3D objects (fixed image)
              http://moi3d.com/forum/get_attachment.php?webtag=MOI_FRANCAIS&hash=b954ab3d624002e07167f174de2e9b59&filename=test pluginThomthom.png
              Process in Sketchup! ๐Ÿค“
              http://moi3d.com/forum/get_attachment.php?webtag=MOI_FRANCAIS&hash=a657bb9f79277833718ed8c62d36de7b&filename=test pluginThomthom.gif
              • 2 / 2
