    [Plugin]Group in Component
    25 Posts 9 Posters 19.0k Views 9 Watching
    • Chris FullmerC Offline
      Any explanation what this most recent file is? Thanks!
        From Google Translate:
        The script takes the group into components. The same group replaces one component.
        Here's an example file: look at the statistics
        Pech_SU5.zip
        (290.92 KiB) Not downloaded yet
        Consists of a group size of 756 kb, 155 groups
        Select all and apply the script.
        File size reduced to 500 kb
        PS: The script is not finished yet, it lacks precision, but rather did not not work.
        • chriC Offline
          chri
          hi Sahi
          you have done a great job 👍 👍
          seems to work with SKECHUP 8 and 2013
          Doesn't work with SKETCHUP 6 2014 2015
          Thanks again
          Chri
            glro
            @chri said:
            hi Sahi
            Thanks again
            Chri
            i wish i could get the same result on my computer
            i only get an error message
            • chriC Offline
              chri
              in english
              You will find here , my system and my plugin file if it can help you .
              en français
              Bonjour
              Trouves ci-joint des images de ma configuration et le fichier ruby correspondant a notre sujet .
              Salutations
              Chri
              components.rb
                glro
                @chri said:
                in english
                en français
                Bonjour
                Salutations
                Chri
                Thank you !
                i don't know why, but with the file you put in line, i don't get the error message
                it worked also on my computer: the plugin makes components out of groups if they are square boxes
                From the test i made, the square boxes must have been made into a group and then duplicated, before the plugin is used; otherwise the plugin doesn't recognize them as identical and makes 2 different components
                it could be possible maybe to make it work for other types of groups; by checking the distance between the corners of the bounding box, for example
                i shall try
                • chriC Offline
                  chri
                  Hi Giro
                  I agree with you , when you tell "... must have been made into a group and then duplicated, before the plugin is used "
                  ... but, i don't understand the meaning of "square boxes" and "other types of groups"
                  for me, there are only 2 possibilty; a group and non-grouped entities!
                  Sincerely
                  Chri
                  BEFORE.skp
                  AFTER.skp
                    glro
                    @chri said:
                    Hi Giro
                    Sincerely
                    Chri
                    you are right
                    i mixed the 2 condition, but only one is true: ""... must have been made into a group and then duplicated, before the plugin is used "
                    this is very limitating, though
                    I was planning to use this plugin on a sketchup model imported from solidworks using SIMLAB converter
                    SIMLAB converts components into groups, and i was planning to use "components.rb" to convert them back to components
                    it doesn't work; i shall try to tweak the plugin to make it work, using the position of the bounding box corners
                    • chriC Offline
                      chri
                      Hi Giro
                      I have made a test with parts imported from STEP files ( using Moment Of Inspiration ).
                      I noticed that when parts contains a lots of entities , it's common to have small differences after import
                      Perhaps , you have this kind of problem with your file .
                      ... so , the plugin cound not recognize almost similar components .
                      Chri
                        glro
                        @chri said:
                        Hi Giro
                        Chri
                        interesting
                        It might be an explanation, but not in any case
                        i make a cube, grouping the faces
                        i duplicate it
                        i launch the plugin: they are both turned into instances of the same component
                        now, i explode them
                        turn again each one of them into a group
                        and finally i launch the plugin: they are turned into instances of 2 different components
                          Hello
                          Here a little trick that can help you 😉
                          The use of the cool plugin by Thomthom Components Comparison ☀
                          As there are not yet system of instancied Objects / Group in Moi3D for export to Sketchup we must make a little tricky thing! 😄
                          Say I have 2 Objects (here a cube duplicated) in Moi3D, I export them in 3DS Format
                          Import in Sketchup / Explode one time
                          so we have 2 Components triangulated named OBJ1, OBJ2
                          Launch the Components Comparaison and Bingo we have now instancied Components! 😎
                          Triangulation can be cleaned by plugin Clean Up by Thomthom again!
                          http://s6.postimg.org/ufh8iq7gx/2cubes_de_moi.jpg
                          Result will be the same with 2 different cubes but with the sames dimensions! 😉
                          http://s6.postimg.org/nqap2pm4x/tictic.jpg
                          With more complex objects there is something more to make!
                          That is failing or one object is rotated!
                          Failed ? 😮
                          http://s6.postimg.org/dhmtamngx/alas.jpg
                          Rotated ? 😮
                          http://s6.postimg.org/sevabn0pd/tuctuc.jpg
                          For resolve this you must just find the good tolerance inside the Thomthom pluging! Don't hesitate to push it! 🤓
                          Of course many object can be treated in the same time as Shown in this Chri's Video! 😉
                          The start Moi3D objects (fixed image)
                          http://moi3d.com/forum/get_attachment.php?webtag=MOI_FRANCAIS&hash=b954ab3d624002e07167f174de2e9b59&filename=test pluginThomthom.png
                          Process in Sketchup! 🤓
                          http://moi3d.com/forum/get_attachment.php?webtag=MOI_FRANCAIS&hash=a657bb9f79277833718ed8c62d36de7b&filename=test pluginThomthom.gif
                          • 2 / 2
