    One controller
    21 Posts 3 Posters 3.2k Views 3 Watching
    • V Offline
      Vtec234
      Hello! I have a problem with controlled joints: I need only one slider controller for 4 joints, but I don't know how to do it! Please, help πŸ˜„
      • V Offline
        Vtec234
        Or maybe could someone tell me how to make a script, that when you press "up" those 4 servo joints will make the wheels turn?
        • H Offline
          hobbnob
          key("up")
          sipmly put all of that in the little blue thing with the slider name so that it isn't slider('test') anymore
          My WIP Thread:Here
          • V Offline
            Vtec234
            ok but how to make that up is forward and down is backward?
            @EDIT
            Because I made a car and when I press "up" the car doesn't move because wheels turn in other directions!
            • H Offline
              hpnisse
              Hello!
              if key("Up")==1
                setVar("drive",1)
              elsif key("Down")==1
                setVar("drive",-1)
              else
                setVar("drive",0)
              Put this code somewhere in the model, and on the motors (that will let the car go forward/backwards), put this in controller field:
              getVar("drive")
              This should let you control the car with up/down arrows. (when you don't push either up/down the motors will stops)
              And if you want to steer your car you can use the same code with some changes.
              if key("Left")==1
                setVar("steer",1)
              elsif key("Right")==1
                setVar("steer",-1)
              else
                setVar("steer",0)
              And in the servo joints, there shall be only one of the field "Max"/"Min" with numbers (degree of rotation of the wheels), and the other of these two fields will be empty (set to zero "0").
              And the controller field in the servo will have
              getVar("steer")
              hope this helps!
              /hpnisse
              ** %(#BF0000)[/hpnisse]**
              %(#000000)[Windows 7 U] %(#000000)[-]%(#408000)[Sketchup 8] %(#000000)[-]%(#4000FF)[SketchyPhysics 3.2-Dec2] - from Sweden
              • V Offline
                Vtec234
                wow thx ur good πŸ˜„
                ow but i dont have an idea where to put
                if key("Up")==1
                  setVar("drive",1)
                  setVar("drive",-1)
                else
                  setVar("drive",0)
                • H Offline
                  hpnisse
                  Somewhere in the model, just create a static box or something and put this (and the steering script) in the "ontick" field!
                  Then it will work πŸ˜„
                  • V Offline
                    Vtec234
                    wow thx my friend xD
                    • H Offline
                      hobbnob
                      same thing as hpinsse's script, just all in one place:
                      setVar("drive",-(0.5-righty))
                      both do exactly the same thing, just that's shorter.
                      My WIP Thread:Here
                      • V Offline
                        Vtec234
                        umm yea now i made a car (without steering, just forward and backward), but it doesn't move backward, only forward O.o A standard question: what is going on? xD
                        • H Offline
                          hobbnob
                          what scripts did you use?
                          My WIP Thread:Here
                          • V Offline
                            Vtec234
                            well i used the hpnisse's script, now im trying yours
                            • V Offline
                              Vtec234
                              both don't work backward πŸ˜•
                              • H Offline
                                hpnisse
                                I've got both work correct both forward and backwards.
                                Download and look this model.
                                hpnisse vs hobbnob.skp
                                I don't know what you did but here I got both working with the up/down arrowkeys at same time.
                                Hope this helps understanding! πŸ˜„
                                /hpnisse
                                • V Offline
                                  Vtec234
                                  i checked it... and yea it works, but in my model, i think that its something with wheels... check this:
                                  Car
                                  • H Offline
                                    hpnisse
                                    You use servo as motor, I changed it so all servo is the "motor" joint insted. and it work perfect. πŸ˜‰
                                    Then I use my script and changed some stuffs so it would be easy to change the speed.
                                    SamochΓ³d.skp
                                    To change the speed of the wheels then change the number "3" in the "Speed" box.
                                    if frame==1
                                    setVar("speed",3)
                                    then it will work fine.
                                    /hpnisse
                                    • V Offline
                                      Vtec234
                                      ow... thanks i didn't think about the motor joint πŸ˜„
                                      thank you guys for all the help - this forum users are really intelligent - the car works perfecto πŸ˜‰
                                      • H Offline
                                        hpnisse
                                        Good that your happy. πŸ˜„
                                        Have a nice summer!
                                        • V Offline
                                          Vtec234
                                          Thanks and you too ;D Ow, but an other question - what scripting language is it written in?
                                          @EDIT
                                          Because some of those Sketchy things are in Ruby.. but i think SketchyPhysics doesn't use it...
                                          • H Offline
                                            hpnisse
                                            It should be in ruby I think.
                                            http://sketchyphysics.wikia.com/wiki/Ruby
                                            It says that Ruby is used to control SketchupPhysics so I think SP would be written in that script.
                                            • 1 / 2
