    Creating a Custom Line Tool
    9 Posts 5 Posters 1.1k Views 5 Watching
    • K Offline
      kwalkerman
      I just had an idea. I think it should be possible, but there is no official documentation:
      class Custom_Line_Tool < Sketchup::SketchTool
      def initialize
      super
      def onLButtonUP(flags, x, y, view)
      do whatever special stuff you want...
      This would get us to a place where we can use the native sketchup tool stuff (inference locking, line tool image, use of crosshairs if that is what the user wanted, native use of the VCB...) We could then have the tool do custom things, and treat it as a custom tool. However, 'Sketchup::SketchTool' doesn't return anything useful. Any other ideas of things to try?
      We'd also need to know how native sketchup names the input point, and probably a few other things. I do have a custom line tool working, but the original is just more elegant.
      Karen
        That would have been great - but unfortunately not possible. They are implemented in C and there is no documentation nor externally exposed.
        But the line tool isn't that complicated. It's mostly just the InputPoints and inference locking you need.
        • K Offline
          kwalkerman
          Ah, too bad. Of course I want a custom move tool and rectangle tool as well. I do have a line tool working with inference locking and and the VCB activated.
          well, for future, I'll post my line tool:
          class Custom_Line
          def initialize
          @cursor = UI.create_cursor("Cursor.tiff",1,1)
          end # def initialize
          def activate
          $ip = Sketchup::InputPoint.new
          Sketchup.active_model.selection.clear
          @ip1 = nil
          def onSetCursor
          UI.set_cursor(@cursor)
          def onMouseMove(flags, x, y, view)
          $ip.pick(view, x, y)
          view.invalidate
          def draw(view)
          $ip.draw(view)
          if(@pt1 == nil)
          view = view.draw_line $ip.position, $ip.position
          else
          Sketchup.vcb_label = @pt1.distance($ip.position).to_s
          view = view.draw_line @pt1, $ip.position #draws line from last point to current position
          view.invalidate
          def onKeyUp(key, repeat, flags, view)
          if(key==16)
          view.lock_inference
          def enableVCB?
          return true
          def onUserText(text, view)
          begin
          if(@pt1 != nil)
          value = text.to_l # convert the value to a length
          point2 = [$ip.position]
          dist = @pt1.distance(point2)
          w2 = value/dist
          w1 = 1-w2
          @pt2 = Geom::Point3d.linear_combination w1, @pt1, w2, point2
          line = Sketchup.active_model.entities.add_edges @pt1, @pt2 # RIGHT NOW, JUST ADDS TO THE BASE LEVEL
          line[0].set_attribute "EPdict", "Tool", "Node/Branch"
          @pt1 = @pt2
          Sketchup.vcb_value = ''
          rescue
          # Error parsing the text
          UI.beep
          value = nil
          def onKeyDown(key, repeat, flags, view)
          if(key==16&&@pt1!=nil)
          ip1 = Sketchup::InputPoint.new(@pt1)
          @pt2 = $ip.position
          ip2 = Sketchup::InputPoint.new(@pt2)
          view.lock_inference(ip1,ip2)
          def onLButtonUp(flags, x, y, view)
          if(@pt1 == nil)
          @pt1 = [$ip.position]
          else
          @pt2 = [$ip.position]
          @pt1 = @pt2
          Sketchup.active_model.active_view.invalidate
          end # if state
            Can you repost that in the [code] tag - preserver the formatting and much easier to read.
            I'll have a look when I get home.
            • K Offline
              kwalkerman
              Cool. Here it is formatted. As of right now, the line is always added to Sketchup.model.entities. I will need to have it add to the active path... just haven't gotten there yet. Otherwise, it seems to work.
              Karen
              class Custom_Line
              def initialize
              def activate
               $ip = Sketchup;;InputPoint.new
               @ip1 = nil
              def onSetCursor
               view.invalidate
              def draw(view)
               $ip.draw(view)
               if(@pt1 == nil)
               else
                view.invalidate
               if(key==16)
                view.lock_inference
              def enableVCB?
               return true
               begin
                if(@pt1 != nil)
                 w2 = value/dist
                 w1 = 1-w2
                 @pt2 = Geom;;Point3d.linear_combination w1, @pt1, w2, point2
                 @pt1 = @pt2
               rescue
                UI.beep
                value = nil
                ip1 = Sketchup;;InputPoint.new(@pt1)
                @pt2 = $ip.position
                ip2 = Sketchup;;InputPoint.new(@pt2)
               if(@pt1 == nil)
               else
                @pt1 = @pt2
              • Dan RathbunD Offline
                Dan Rathbun
                Karen, what's different about your edition, from the Google supplied sample: Plugins/Examples/linetool.rb ??
                And Sketchup can use TIFFs as button images?? ..any advantage in doing that rather than PNG ?
                I'm not here much anymore.
                • K Offline
                  kwalkerman
                  Hmm... somehow my 'linetool.rb' file got put in the plugins folder and I didn't know that I had it... There are many differences (other than the obvious ones that theirs draws a construction line not an edge, and doesn't start a new line where the old one leaves off). They also work primarily with input points, where I convert earlier to point3d, which means that to do inferencing, I have to convert back.
                  Also, in order to get the tool to write into the active group, $entities = Sketchup.active_model.acitve_entities (not Sketchup.active_model.entities) or (as in 'linetool.rb' view.model.entities).
                  Karen
                    Jim
                    The built-in Line tool seems very simple until you try to recreate it. It has a lot more states (and ways to transition) than I realized at first glance.
                    • Chris FullmerC Offline
                      I agree. I tried to use the linetool to learn how to make a tool, as the API suggests. I got so confused. It is a pretty complex tool, at least more complex than it should be if it is being pointed to as a good script for beginners to learn from.
                      Chris
                      All my Plugins I've written
