    SketchyPhysics cancel use of arrow keys in others Plugins
    6 Posts 3 Posters 751 Views 3 Watching
    • OxerO Offline
      Oxer
      Hi!
      I have found an incompatibility of SketchyPhysics with others plugins that use the arrow keys in any of theirs options, for example:
      • Shape Bender use the UP Arrow key and DOWN Arrow key to toggle the orientation of the bend.
      • LSS Tools>> Interact with control points (ctrlpnts.rb) use adjust 'power' value by hitting arrow keys: up-arrow> increments 'power', down-arrow> decrements 'power', right-arrow> increases incremental value (min=0.1), left-arrow> decreases incremental value (max=3.0).
        In both cases the arrow keys don't work, the plugins work fine only these options don't work.
        I work on Mac, i don't know if this happens in Windows.
      Somebody can help me?
      Thanks!
      [http://www.oxervision.blogspot.com/(http://www.oxervision.blogspot.com/)]
      • Chris FullmerC Offline
        It is a known issue that I had thought was cleared up. You might go put pressure on Chris Phillips to look into it again.
        Chris
        All my Plugins I've written
        • OxerO Offline
          Oxer
          Hi Chris!
          Excuse me, but i don´t know that this problem had been trated before. Is there a post about this problem?
            I'm not saying it was fixed, I'm saying I thought it was, but obviously not. Chris at one point waws aware of it. I guess he never got around to changing his code. Reminders from the community might help. But if almost no one is experiencing the problem, then he might not find it important enough to spend time on.
            Chris
              I think you can also try page up and page down or maybe home and end. See if those will work in Shape bender.
              I know I had this conversation in the past, I might have to reread the shape bender thread to see if anything ever came of it.
              Chris
                CPhillips
                I am looking at this bug now. It doesn't seem to happen under Win. Can anyone confirm if it is a Mac only bug or not?
                Chris
