    Finished my Kreg collections
    7 Posts 4 Posters 3.6k Views 4 Watching
      TDanielsPA
      Kreg pocket holes and screws topic on Kreg Jig Owners CommunityKreg Jig Owners Community.
      Kreg pocket holes:
      http://sketchup.google.com/3dwarehouse/download?mid=8d43a3822e4ebd21d8ebce18f539d6a7&rtyp=lt&ctyp=other&ts=1275409572000
      Kreg pocket screws:
      http://sketchup.google.com/3dwarehouse/download?mid=d242d0d3ea059c74d8ebce18f539d6a7&rtyp=lt&ctyp=other&ts=1275403829000
        mics_54
        spiffy!
        • dermotcollD Offline
          dermotcoll
          Nice work Tim. I could never be bothered to show the kreg jig holes in my projects - now I have no excuse. Thankyou.
          When you burn your arse - you gotta sit on the blisters!!
            Nice. The pocket holes would be even better if you were to make them components and set their axes so they could be quickly and accurately placed.
            The screw file size could be reduced, too.
            Looks like you did reduce the file size in the set of screws.
              TDanielsPA
              Both the screws and the holes are components with their axes set, as can be seen in the video I made about them.
                TDanielsPA
                I don't use the screws in most models though, the holes show the joinery fine without taking up much space. The screws are good however to play around with non standard joints.
                http://api.ning.com/files/YymGaXavHtDup*Fj4nvZoZ29wYsmhS*vZqoKxnTgqlxdgTx-gwtXBaK33ZK1S8YQQlbNBzPFMsWIw6oC8XHvWc*SAJV4zD3Z/225miter2.jpg?width=721
                  If you download them directly from the warehouse they don't open as components. I see that if you search from the Components browser they do insert as components.
