    Oscillator (Where to find?)
    10 Posts 4 Posters 1.7k Views 4 Watching
    • G Offline
      GoldenFrog
      Hello fellows. I am making a Sketchyphysics Lego game, and wanted to know how to make a character walk. I've heard the oscillator joint could be of some use, but I'm not sure where to look. Please help. Thanks
      Remember, great minds think alike, and fools never differ.
      • G Offline
        GoldenFrog
        Thank you very much! I'll be sure to try it!
        • G Offline
          GoldenFrog
          I tryed it, and it works. Ther's only one problem. How can I make a key control the oscillator?
          • H Offline
            hpnisse
            Put
            if key("W")==1; oscillator(50);else;0;end
            in the controller box.
            Change the key and oscillator speed by change the "W" to something else ("Space","Shift" etc) and (50) to whatever you want.
            /hpnisse
            edit:
            if you put
            if key("W")==1;oscillator((slider("Oscillator")+1)*20);else;0;end
            in controller box you will get a slider to adjust the speed of the oscillator when you have press the key.
            /edit
            ` /hpnisse`
            ` Windows 7 U -Sketchup 8 -SketchyPhysics 3.2-Dec2 - from Sweden`
            • G Offline
              GoldenFrog
              Will try it, thanks so much guys!! πŸ˜„
              • N Offline
                NOLASaintTM
                When will the thing be done, though?
                "There are only 2 seasons in [color=#008000:29bx2alm]Louisiana[/color:29bx2alm]: [color=#BF0000:29bx2alm]Hurricane Season[/color:29bx2alm] and [color=#BF0000:29bx2alm]Summer[/color:29bx2alm]" My Models: [url:29bx2alm]http://sketchup.google.com/3dwarehouse/search?viewer=06262141413891559654&scoring=m[/url:29bx2alm] [color=#0000FF:29bx2alm]G[/color:29bx2alm][color=#FF0000:29bx2alm]O[/color:29bx2alm][color=#FFBF00:29bx2alm]O[/color:29bx2alm][color=#0000FF:29bx2alm]G[/color:29bx2alm][color=#00BF00:29bx2alm]L[/color:29bx2alm][color=#FF0000:29bx2alm]E[/color:29bx2alm]!!!
                • G Offline
                  GoldenFrog
                  Give me time, give me time. A sketchyphysics game has a lot of work hat needs to go into it. A reasonable etimate is sometime in the latter part of next week.
                  • N Offline
                    NOLASaintTM
                    Thanks!
                      Builder Boy
                      Thank you hpnisse! Now that I know how to use keys, I made this!
                      Use the arrow keys to control it
                      All my plugins
                        Builder Boy
                        I have never been able to figure out how to use the oscillator joint. Instead, I usually use the slider joint. All you have to do is make the slider the right length and then, select it and click the UI button to the left of the joint connection tool. Once you have the UI open, find the controller box.
                        Once you find the controller box, simply type oscillator(500) You can substitute 500 for any number. The higher the number, the slower the object will oscillate. I suggest starting at 500, and then fine tuning it.
                        All my plugins
