    Problem while creating a circle ?!
    4 Posts 2 Posters 465 Views 2 Watching
    • M
      Morgan74
      Hello everybody,
      I'm trying to draw and paint a circle in the center of a Face, so here is my code :
      The current selection is a Face :
      center = Sketchup.active_model.selection.first.bounds.center
      normal = Sketchup.active_model.selection.first.normal
      outline = Sketchup.active_model.entities.add_circle(center,normal,10)
      circle = Sketchup.active_model.entities.add_face(outline)
      circle.material = "red"
      This code draw a circle but "add_face" always return nil so I can't paint in red this new circle !??
      Can't you help me please, because I don't understand the problem?
      • thomthomT
        Since you are drawing onto a face, when you try to make a face from the circle edges, there is already one there, and unfortunately it returns nil if it does not create a new face.
        ` face = Sketchup.active_model.selection.first # Keep track of the original face
        center = face.bounds.center
        normal = face.normal
        assume that the circle edges borders to the new circle and the original face
        circleface = ( circle.first.faces.to_a - [face] ).first
        circleface.material = "red"`
        • M
          Morgan74
          Thanks a lot for your reply!!
          It's really better now !!
          But with circleface = ( **outline**.first.faces.to_a - [face] ).first
          • thomthomT
            ooops! 😳
