    Observers not garbage collected?
    3 Posts 2 Posters 412 Views 2 Watching
    • thomthomT
      Create an observer class...
      class ObTest < Sketchup::ModelObserver; def onTransactionUndo(model); puts 'onTransactionUndo'; end; end; nil model=Sketchup.active_model #<Sketchup::Model:0xf584d10>
      Create an model observer and test it...
      x = ObTest.new #<ObTest:0xf4f5568> model.add_observer( x ) true onTransactionUndo onTransactionUndo onTransactionUndo
      Check the instance count for the observer...
      ObjectSpace.each_object(ObTest){} 1
      As expected.
      Remove the observer...
      model.remove_observer( x ) true ObjectSpace.each_object(ObTest){} 1
      Still one - but we have not triggered the GC yet.
      Trigger the GC...
      GC.start nil ObjectSpace.each_object(ObTest){} 1
      Still there! This is not expected.
      Set our instance reference to nil...
      x=nil nil GC.start nil ObjectSpace.each_object(ObTest){} 1
      Still there!!
      Any ideas?
      Bug?
      • Dan RathbunD
        Dan Rathbun
        Yes a bug in a way... the call to add_observer creates a C++ reference to the object that is not released by the remove_observer call.
        So ..Ruby GC cannot dispose of the object.
        In the test code below, you'll see the object is GC'd when the add_observer and remove_observer calls are commented out.
        OT.rb
        I'm not here much anymore.
        • thomthomT
          This is somewhat troublesome.
          One would then have to be very careful when creating observer instances. Ideally only create one instance - ever, if possible.
          And also clean up any references the observer has to other objects when possible, as otherwise they won't be GC'd either.
          grumble refactoring time.
