    Scale in Sketchy Physics
    3 Posts 2 Posters 1.1k Views 2 Watching
    • C
      cholme
      I was wondering if there is a way to change the default size of the Physics components when they are created. For instance, I am a furniture maker so I am working in inch models. When I model a hinge that is 3", and I attach a SketchyPhysics "hinge" component it is absolutely huge, and makes it difficult to work with. Obviously I hide them in the final render, but it would be nice to not have to resize every component each time.
      Thanks.
      P.S. I am using SketchPhysics 3 for Mac.
      • H
        hpnisse
        You can try to scale the physics components in there own file.
        find your ...Plugin\SketchyPhysics3\Joints... folder and go in to every "joint".skp and try to scale it down, try with one first and see if it really works correct when you start physics simulation.
        I don't know if this works but you can always try.
        /hpnisse
        ** %(#BF0000)[/hpnisse]**
        %(#000000)[Windows 7 U] %(#000000)[-]%(#408000)[Sketchup 8] %(#000000)[-]%(#4000FF)[SketchyPhysics 3.2-Dec2] - from Sweden
        • C
          cholme
          Awesome!!! That did the trick.
          Thanks so much.
