    Question about the vector direction
    4 Posts 3 Posters 528 Views 3 Watching
    • W Offline
      wing8b
      Hi, I am new to Sketchup and Ruby, and I am now using SketchUp 7.
      I wonder why the following 2 scripts would have the same result. I suppose them should be in opposite direction...
      Script#1:
      ` centerpoint = Geom::Point3d.new
      Create a circle perpendicular to the normal or Z axis
      vector = Geom::Vector3d.new 0,0,1
      vector2 = vector.normalize!
      model = Sketchup.active_model
      entities = model.active_entities
      edges = entities.add_circle centerpoint, vector2, 5
      face = entities.add_face edges
      status = face.pushpull 100, true`
      Script#2:
      vector = Geom::Vector3d.new 0,0,-1
      Can anyone advise me on that? Thanks!
      • Chris FullmerC Offline
        Yes, it does exactly what you think it should. The vector in script 1 points upwards, while the other points downwards.
        But in SketchUp, any face that is created on z = 0 (the groundplane) that face is always facing downwards. So that effectively overwrites the vector you used in making the circle. In both scripts, try changing the first line to
        centerpoint = Geom::Point3d.new(10,10,10)
        So that it creates the circle up off the groundplane. Then you will see the results you expect where script 1 the tube goes upwards and script 2 the tube goes downwards.
        Hope that helps,
        Chris
        All my Plugins I've written
          A good practice might be to test the normal of the face after it is created. If it's z direction does not match the vector's z direction (vector points upwards but face points downwards) then you should reverse the face, and then proceed with the rest of the script.
            MartinRinehart
            This bit of code is unusual:
            vector = ...
            By convention, Ruby methods that end with a "!" work directly on the calling object's data. So vector.normalize! normalizes vector. You now have the normalized data in vector and a second reference to it in vector2. Not sure that was what you intended.
            I added a comment to the Vector3d class doc to clarify this. (If you learned from the doc you were misled.)
            Author, Edges to Rubies - The Complete SketchUp Tutorial at http://www.MartinRinehart.com/models/tutorial.
