    Seasonal animations
    20 Posts 3 Posters 3.5k Views 3 Watching
    • D
      danbig
      Hi All -
      Here's an idea I've been toying with:
      I like how you can set up an animation, where you watch the shadows play over your model from morning to night or whatever.
      I'm wondering if it's possible to create an animation for a whole year.
      I know this could be rigged by creating many many scenes, but I'm thinking you can set one scene to Jan 1, and the next to Dec 31, and then set some timing and playback options, etc..
      Then, you can sit back and watch the shadows as they appear throughout the year, not just for one day.
      Currently, if you set once scene in Jan, and one in Dec, the animation of the shading just transitions from one date to the next, without showing all the days in between.
      The result of the animation I'm thinking of would look similar to a time lapse nature video that shows many months in a few minutes.
      Has anyone seen anything like this?
      • Chris FullmerC
        Interesting Dan, I have not tried that but I am a big fan of time lapse. I do not think it will work as you wish it did, but a script could be written rather quickly to make a scene for the morning and night for every day in the year.
        I would guess the script would set up a scene for 12:00am and one for 12:00pm each day. That is 2 scenes per day, 365 days of the year. A total of 730 scenes. Then just export that as a video. That could be kind of cool.
        Chris
        All my Plugins I've written
        • Chris FullmerC
          Here you go Dan, paste this code into the Ruby Console and hit enter.
          Code removed because it didn't work.  Check the next post for updated code.
          Delete all other scenes in the model first (or at least set them so that do not participate in the animation). This will create 1 scene per day, right at midnight. Then output it with a transition time for however many seconds per day the animation should take. I'll try it now and post a video later tonight if it ever finishes rednering.
          Chris
          • Chris FullmerC
            Darn, that code does not work. The shadows never went into day time - oops! I'll re-write it to do midnight, then noon, like I had first thought. So try this (for all you following along at home...anyone? 😆 )
            EDIT: The code posted below will help make a video like this:
            [flash=853,505:1482w5w5]http://www.youtube.com/v/5pxREh1670A&hl=en_US&fs=1&rel=0[/flash:1482w5w5]
            model = Sketchup.active_model; si = model.shadow_info; ps = model.pages; si["DisplayShadows"]= true; t = Time.gm(2010,"jan",1,0,0,0).to_i; 365.times { |day| si["ShadowTime_time_t"]=t; ps.add; t = t + (60 * 60 * 12);si["ShadowTime_time_t"]=t; ps.add; t = t + (60 * 60 * 12);}
            Chris
            EDIT: And notice that this will make 2 scenes per day, so if you want 1 second per day, set it to 0.5 seconds per scene.
            • Chris FullmerC
              ok, that seems to be working right now. I've got an animation set up and exporting. It should finish in the next 5 to 10 hours. I'll upload it and post it here tonight (in about 12-18 hours).
              Chris
              EDIT: I posted the video above.
              • D
                danbig
                This. Is. AWESOME! I stand in awe of you scripting skills.
                I hope you have good luck with exporting the animation. Monday, after work is done, I'll start rendering a year's worth of shadows, and hopefully it will be done when I come back Tuesday morning.
                I have two questions about customizing this script:
                Is it hard to add screen text automatically? For example, I did a much shorter time lapse manually, and I had text on screen that displayed the month and date. Kind of like a progress or status for the viewer.
                Can you help me understand the anatomy of the script you uploaded? For example, can I change the start and end points for each day? (so the animation would only show 10am to 5pm, or 9am to 6pm, etc..). Can I change the range of dates? (so the time lapse would only cover Feb through July, etc..).
                Best,
                Dan
                • Chris FullmerC
                  yeah, the script is fairly simple. It sets the current date to Jan 1st at midnight, 2010. Then it turns on shadows, then it runs through a loop 365 times. The loop makes a page, then addes 12 hours to the current time, then adds another page, then the loop starts over.
                  So you can easily change the start date. The line t = Time.gm(2010,"jan",1,0,0,0).to_i you can adjust "jan" to "feb" and 1,0,0,0 is the date (1) and 0,0,0 is the hours, minutes and seconds. And instead of running 365 times, it should only run like 150 times, or however many days you want it to cover.
                  I fininshed a few minutes of the video (EDIT: the video which is now posted above) and it is really pretty boring. Well, it just doesn't clearly show anything. I think it might be more interesting if it did like you suggested and started and ended at specific times. Or it might be interesting to just show noon every day of the year, so you can see how the shadows dance around.
                  I have dreams of doing this work with a real camera some day. I get pretty excited about it.
                  Chris
                  • D
                    danbig
                    Hmmm.
                    I didn't export any video, but I did watch some of the animation from within SketchUp. It really has potential to do exactly what I'm looking for, which is to allow the viewer to tell if the shadow from a specific object will shade another object at any time during the year.
                    I did reduce the scene time to .125 seconds, which compressed a whole year into 1.5 minutes of animation. For shorter durations, I think longer scene times would be cool too.
                    So, going off of your description of how to modify the code block: Say I want to set it to create scenes for the month of August, and I want the first scene of the day to be at 7am, and the last scene of the day to be at 1pm. Is this the correct code? (all other code as you posted above)
                    t = Time.gm(2010,"aug",1,7,0,0).to_i; 31.times
                    I don't see where the script would tell the second scene to be at 1pm, so I'm thinking this would create one scene at 7am, and the next scene exactly 24 hours later?
                    • Chris FullmerC
                      model = Sketchup.active_model;si = model.shadow_info;ps = model.pages;si["DisplayShadows"]= true;t = Time.gm(2010,"jan",1,12,0,0).to_i;365.times { |day| si["ShadowTime_time_t"]=t;ps.add;t= t+(60 * 60 * 24);}
                      This code will make 1 scene at noon, every day of the year. Then set up your animation so it exports 1 frame per scene. You get a great animation of the shadows moving around. I'm rendering it right now, but I can already see from the exported images that its coming out nicely. The video below is a product of the code snippet in this post.
                      [flash=853,505:495gh9fp]http://www.youtube.com/v/8RfK_LuwZVg&hl=en_US&fs=1&rel=0[/flash:495gh9fp]
                      Chris
                      • Chris FullmerC
                        t= t+(60 * 60 * 24)
                        That line is what adds 24 hours to the current day. So first set it to the day you want, then add time to that day. There are plenty of other ways to do it, but that is how I've done it.
                        Are you using a multi-line editor by chance? Like Jim's web console or Alex's Ruby Console upgrade? I'll start writing the code in an easier to read manner if you have one of those installed.
                        Chris
                        • D
                          danbig
                          I do have Jim's Web console installed. Is Alex's console better?
                          So, here's my stab at creating a scene for every day in August, from 10am to 4pm:
                              model = Sketchup.active_model;si = model.shadow_info;ps = model.pages;si["DisplayShadows"]= true;t = Time.gm(2010,"aug",1,10,0,0).to_i;31.times { |day| si["ShadowTime_time_t"]=t;ps.add;t= t+(60 * 60 * 6);}
                          When I ran this script, I ended up with 4 scenes per day. (4am, 10am, 4pm, 10pm)(the very first day had only three scenes, as it didn't create a 4am scene)
                          Maybe I should modify the first version of the sript? (trying now)
                          • D
                            danbig
                            This code accomplishes what I described above.
                            model = Sketchup.active_model; si = model.shadow_info; ps = model.pages; si["DisplayShadows"]= true; t = Time.gm(2010,"aug",1,10,0,0).to_i; 31.times { |day| si["ShadowTime_time_t"]=t; ps.add; t = t + (60 * 60 * 6);si["ShadowTime_time_t"]=t; ps.add; t = t + (60 * 60 * 18);}
                            For the month of August, it creates two scenes per day. The first is at 10am, and the second is at 4pm.
                            This line works as you described above: it sets the time to August, starting at 10am, and sets it to repeat 31x.
                            The first time this line appears, the "6" is the time after first scene that I want to create the second scene. (10am + 6hrs = 4pm)
                            t + (60 * 60 * 6)
                            The second time this line appears, the "18" is the time after the second scene until the first scene the next day (4pm + 18hrs = 10am the following day).
                            Now onto displaying the current month/day onscreen for each scene....
                            By the way, are you using the export to AVI function to create your animation, or some other method? It sounded like above you were exporting an image for each scene, which you would then compile into a video. This would be very cool, but you would lose the transition effect that sketchup performs between scenes, right?
                            • Chris FullmerC
                              EDIT: ok, you already figured-out most of what I explain below.
                              ps = model.pages
                              31.times do |day|
                              	ps.add
                              	t= t+(60 * 60 * 6)
                              Since you have a multi line editor, you should be looking at this in regular notation I think, instead of condensing it all onto a single line. So this (above) is your code from your previous post. It sets the time to 10:am on the first day. Then begins the loop 31 times. Its adds the first scene - at 10:00. THen adds 6 hours to the current time and repeats the loop. Add 6 hours, add a scene, add 6 hours, add a scene.
                              You are close, but you are missing 2 things. First, you want to add hours to get to 4:00pm, then you need to 18 hours to get back to 10:00 the next day.
                              Also, you don't want the animation to animate between the 4pm and 10am scene. So you will need to set that scene to not have a transition time. In Ruby, you can set scenes to use the default transition time specified in the model tab. OR, you can set a scene to have its own transition time that overides the default. You're going to need to do that to set the transition to zero so you get a full animation of shadows during the day, then no transition, just skip right into the next day. This is the code that does what you are looking for (I think). Try it out.
                              ps = model.pages
                              31.times do |day|
                              	page = ps.add
                              	page.transition_time = 0.0
                              	t= t+(60 * 60 * 6)
                              	page = ps.add
                              	page.transition_time = -1
                              	t= t+(60 * 60 * 18)
                              And check out my youtube videos channel (in my signature link) and I've got 2 videos uploaded or uploading there. The good one is the one that does noon at every day throughout the year. It came out looking great.
                              Chris
                              • Chris FullmerC
                                Hey Dan, ok I posted the videos above. They came out as I said before - the first one is rather difficult to watch (boring) and does not show much anything interesting. The second one is cool though. I am also hoping to post a video of the recent code snippet I posted where it just shows the hours of the day for a month. Maybe I'll get that done tonight still.
                                For video export, I export to jpegs for pngs. SU will export each frame as a separate image. Not each scene, but actually each frame. So if you set it to export 20 frames per second, and have 2 seconds for each scene transition, then it will export 40 jpegs per scene. That is how I always export my movies from SU for quality reasons. I then turn that image sequence into a single movie using quicktime Pro, but there are free softwares that also do it.
                                Chris
                                • D
                                  danbig
                                  Hi Chris -
                                  The videos both look great. I agree that the second approach, with only one time stamp per day, makes for a more interesting animation.
                                  Do you know if it's possible to show shadows for more than one time at the same time?
                                  I added
                                  status = page.use_camera=false
                                  in two places below. As I'm sure you know, this makes it so that the scenes do not save the camera position from when the script was run.
                                  ps = model.pages
                                  #set the year, month, day, and time of first shading scene
                                  #set number of days to repeat
                                  31.times do |day|
                                  page = ps.add
                                  t= t+(60 * 60 * 6)
                                  page = ps.add
                                  t= t+(60 * 60 * 18)
                                  I've moved onto trying to add screen text, which notes the month and day of the current shadow displayed. I'm thinking this will be more involved than turning off the camera location save. Any ideas, anyone? The end result would be in the finished animation, there would be a time stamp of sorts on the screen as the animation plays back.
                                  • D
                                    danbig
                                    Ok, so turning the camera location off in the first script worked fine.
                                    When I tried to insert the extra line into the one time stamp per day version, this is what happened:
                                    (eval):9:in ‘initialize’: undefined method ‘use_camera=’ for #Sketchup::Pages:0x16f5d910
                                    Here's how I put the status line into the code:
                                    ps = model.pages
                                    ps.add
                                    status = ps.use_camera = false
                                    • Chris FullmerC
                                      NOTE: in the rext of the post I use the word "page" a lot. It is interchangeable with "scene".
                                      The variable ps is pointing to the entire collection of pages - not just a single page. The use_camera= method works on a single page, not a pages collection. So when you make the page with page.add, you need to make a variable that points to that single new page. Then tell that page to not use the camera. Change these two lines:
                                      ps.add status = ps.use_camera = false
                                      to this:
                                      page = ps.add status = page.use_camera = false
                                      Now when the page is being added to the pages collection, you have the variable page that points directly to that new page. Then you tell that page to not use the camera.
                                      Also, good luck with the time stamp thing. I think the only way to do that is with separate layers FOR EACH DATE you plan to insert. I would guess that you will want to make all the layers first. Then make all the text, and put it on the correct layer as you make it. Then when you make the pages, turn off all the layers for the dates you do not want on. That is the only way I can think to do it.
                                      And lastly, for the dual shadows. There is no way to do that through SketchUp and the API. But it is possible to combine images if you export the animation as frames. You could overlay the dual animations on top of eachother using a batch process in photoshop, or automate it with a free software called imagemagic. Once you get the process down, it is not that hard to do. and if you really had to do this often, could script then entire process so that none of it was manual.
                                      Chris
                                      • D
                                        danbig
                                        Hmm.
                                        Thanks for the tips on the script, and the thoughts on the time stamp. I'm off to read the SketchUp Ruby API.
                                        Best,
                                        Dan
                                        • DavidBoulderD
                                          DavidBoulder
                                          I haven't looked through this entire post, but I like the idea of picking 10-12 days throughout the year for the simulation, or running the simulation for every day of year but first for 8am, then 9am, 10am, etc. So not as jumpy as going through the year chronologically.
                                          Not quite the same, but I had also setup a LayOut project that had pages for the solstices and equinoxes, at 9am, noon, and 3pm. It had a plan and and elevation view on each page. I was using this to study shading devices,so my my elevation was zoomed in on a window.
                                          As long as I was careful how I named my scenes, I could drop swap out my SketchUp fle in my Layout project, and get a quick shadow studies for any project.
                                          David Goldwasser
                                          OpenStudio Developer
                                          • Chris FullmerC
                                            @davidboulder said:
                                            I haven't looked through this entire post.
                                            Good, don't waste your time 😄 Just watch the videos and if there is one you like, then use code associated to that video. Much of the thread was me rambling on and on.
                                            I think that is an neat idea too.
                                            I find myself drawn to video and animation for this type of study personally, but whatever works for what you need it for.
                                            I would like to develop a full script that layers multiple shadow times on top of eachother and colors them differently - maybe blue red and orange or something for morning noon and afternoon, for each day of the year. I think that is potentially a useful script.
                                            Bytheway, Al at renderplus has a script that will layer shadows on top of each other and output them as a single image. I think it is part of his NPR (non-photo-real) toolkit. I'm not sure if it costs or is free. But he developed that after we had some discussions along this line, about how to layer shadows. It is workth looking at.
                                            Chris
