    KT and Dagger
    8 Posts 4 Posters 837 Views 4 Watching
      asirad
      What do you think?
      Thanks for comments.
      Best Regards
      %(#0040BF)[My Polish Blog ------------
      http://3d.na.wroclaw.pl
      • majidM Offline
        majid
        nice start 😄, but maybe you also know that "gods are in details" 😉 so maybe adding some surrounding (maybe a table under the sword, and an environment) may improve the result . 😄
        • K Offline
          KarinaGM
          Nice start 😄
          If the center of the render is the dagger itself and you don't want to place it in an environment, then your model should be much more detailed.
          **"Aquel que sacrifica un poco de libertad por seguridad, no se merece ninguna y terminará perdiendo ambas"
          -Benjamín Franklin.**
            asirad
            Thank you for comments.
            I agree with you. I did not write why I did this model and this is explanation:
            I did model because I had problem with metal material and reflection (specular). As first I received only plastic material and I did not know why. From forum I received information that was a problem with lights and environment. I went to my project and I tried. Effect is OK. I'm new in Kerkythea and I need to learn much more.
            For the end I can say that: for next model I will add some more details and some background.
            Best Regards
            • majidM Offline
              majid
              if you are new to KT , maybe this helps a bit:
              http://forums.sketchucation.com/viewtopic.php?f=80&t=17207 , and also more tight one:
              http://www.pushpullbar.com/forums/showthread.php?10200-Sketchup-Kerky-newbie
                asirad
                Majid thank you a lot.
                Your tutorial is something what I was looking for. Every KT user should start from your tutorial.
                Best Regards
                • majidM Offline
                  majid
                  dear mate, it is just easy to learn and handy, but as I've mentioned ,not totally correct, by the way 😉 cheeres
                    Roger
                    A 1941 Sykes-Fairburn no doubt.
                    http://www.azcreative.com
