    Help with van.
    4 Posts 4 Posters 622 Views 4 Watching
      Slimdog
      I have been trying to model an early 90's Mitsubishi Delica. I started the project because I wanted to design a camperized interior which I have done already. But now I have come back to trying to model the exterior better. The biggest problem I am having is with corners that come together at different radius's. I started out with a side and end profile and then push pulled them together and then intersected with model. I have tried rounding the corners of the window pillars with Fedo's round corner plugin with no success.
      Any other suggestions how I could round the corners on the body?
      http://i60.photobucket.com/albums/h30/slimdog72/Delicaintersect.jpg
      http://i60.photobucket.com/albums/h30/slimdog72/Roundcorner.jpg
        Try the TIG Set Extrude tools πŸ˜‰
        You must have a profil, 2 rails ...
        • EscapeArtistE Offline
          EscapeArtist
          Also they may be too small. Make your shapes life size or 10x life size so that SU can handle the small triangles when you intersect.
            Slimdog
            Thanks for the comments guys.
            I have played with TIG's extrude tools but I am not that good with them. I also dont see how it would work with so many curving surfaces coming together.
            Mike I will try and make them the same hight but the body slopes from front to back and the roof is curved so I dont see how that will help.
            Escapeartist I have modeled the van life size but I will try and enlarge it 10X and then use round corners plugin.
