    Adding Cylinders to Sketch
    4 Posts 2 Posters 324 Views 2 Watching
      corbinw
      I am trying to add cylinders to the top of a board programmatically.
      I have attached the a graphic of the desired result, the circles would pushpull up 5"
      Any help is greatly appreciated.
      Corbin
      The current script is as follows:
      require 'sketchup'
        UI.menu("PlugIns").add_item("Draw board") {
        # Call our new method.
        draw_board
      def draw_board
        # Get "handles" to our model and the Entities collection it contains.
        model = Sketchup.active_model
        entities = model.entities
        # Create a series of "points", each a 3-item array containing x, y, and z.
        pt1 = [0, 0, 0]
        pt2 = [72, 0, 0]
        pt3 = [72, 42, 0]
        pt4 = [0, 42, 0]
        # Call methods on the Entities collection to draw stuff.
        new_face = entities.add_face pt1, pt2, pt3, pt4
        new_face.pushpull 0.75
           normal_vector = Geom;;Vector3d.new(0,0,1)
           radius = 0.2
      (1..10).each { |i|
            # Draw a circles
           center_point = Geom;;Point3d.new(1,i,0)
           edgearray = entities.add_circle center_point, normal_vector, radius
           first_edge = edgearray[0]
           arccurve = first_edge.curve
      What I would like to do programmatically
      Current circles
        (1..10).each { |i|
          # Draw a circles
          # The face will be the one where the outer loop matches the edge array returned by add_circle
          face = first_edge.faces.select { |f| (f.outer_loop.edges & edgearray).length == edgearray.length }.first
          face.pushpull(10)
          corbinw
          That is what I needed, thank you ThomThom.
          I am creating several thousand of these pegs in different locations on the board,I have noticed a real processing hit.
          I read that it would be better to create these objects as components and then add them dynamically? I tried to do a basic example of a component instance and transformation(seems simple with a simple face, but confusing in cylinder)
          What am I missing?
            pt1 = [0, 0, 0]
            pt2 = [20, 0, 0]
            pt3 = [20, 20, 0]
            pt4 = [0, 20, 0]
            # Draw a circle on the ground plane around the origin.
            center_point = Geom;;Point3d.new(1,1,0)
            radius = 0.3
            entities = Sketchup.active_model.entities
            group = Sketchup.active_model.entities.add_group
            face.pushpull 3
            face = group.entities.addface face
            comp = group.to_component
            transformation = Geom;;Transformation.new([2,1,0])
            componentinstance = entities.add_instance(comp.definition, transformation)
            When adding groups components programmatically you got to think somewhat different from when you model.
            When you model you first make the geometry and then group or make a component out of it.
            When you program you create the group or component first and then add the geometry directly inside it.
            pt1 = [0, 0, 0]
            pt2 = [20, 0, 0]
            pt3 = [20, 20, 0]
            pt4 = [0, 20, 0]
            radius = 0.3
            # Make a new component definition
            comp_def = model.definitions.add("Cylinders")
            # Generate the geometry. Note that component definitions has and Entities collection - as model does.
            edgearray = comp_def.entities.add_circle(center_point, normal_vector, radius)
            face.pushpull(3)
            # Now add an instance of hte component to the model
            componentinstance = entities.add_instance(comp_def, transformation)
