    Connecting SketchUp to Pachube v0.2
    5 Posts 2 Posters 901 Views 2 Watching
      toto ete
      i have problems using this plugin:
      http://community.pachube.com/sketchup
      With this tool, you are able to import both realtime and historic Pachube data (i.e. sensor and environment data) into popular 3D CAD package Google SketchUp. The incoming data can be used to generate or modulate a 3D model of a building or environment, and enables sophisticated design-decisions that are based on actual (and not simulated) sensor and environment data. Possible uses include designing interactive façades, undertaking post-occupancy evaluation (which is where you evaluate how well the design performs) and sensor-based form generation.
      Here's a video introduction – it's very basic, but shows how incoming Pachube data can modulate 3D elements (in this case just blocks) inside SketchUp:
      If anyone can help, my system is on windows xp with latest sektchup, the pictures of the popup screen are not there, and the connection to the feed is not connecting. I now that this is a problem for the pachube team but maybe someone is using this too and may have a look into the ruby code.
        Jim
        Hi totoete,
        I've never used it, but are there any errors when you open the Ruby Console window and try to run the plugin?
          toto ete
          hello,
          first of all some grafics in the pop up window e.g. activate enviroment are not displayed but they are all in the images folder but not with absoulte path in the html file. After i wirte the code in the ruby console: load 'pachube2sketchup/start.rb' following text will displayed there:
          true
          Reading Pachube Environment...
          Active Environment is: 1
          It Contains 8 Pachube Enabled Components
          Object 0:
          Type: static
          Connected to Pachube Feed: 1908, Stream Number: 0
          Object 1:
          Type: scaler
          Connected to Pachube Feed: 1908, Stream Number: 2
          Object 2:
          Type: scaler
          Connected to Pachube Feed: 1908, Stream Number: 3
          Object 3:
          Type: scaler
          Object 4:
          Type: scaler
          Connected to Pachube Feed: 1908, Stream Number: 6
          Object 5:
          Type: static
          Connected to Pachube Feed: 0, Stream Number: 0
          Object 6:
          Type: static
          Object 7:
          Type: static
          Matching Entities...
          Logo Detected
          PachubeLogo ...Match Found
          pObj1#1 ...Match Found
          pObj2#1 ...Match Found
          pObj3#1 ...Match Found
          pObj4 ...Match Found
          pObj5 ...Match Found
          pObj6 ...Match Found
          pObj7 ...Match Found
          Loading Object 1 Data...
          everything looks fine. but i thing the loggin makes some problems? i dont know.
          also a javascript error window popup is coming up which says:
          line 129
          sign 9
          error 'pJ.datastreams[....]value.min_value' is zero or no object.
          code 0
          URL file//C:..\p2s.html
          thanks for looking into. maybe its developed only for mac users in mind 😉
            Jim
            Ugh, the plugin it uses all global variables and no namespaces.
            Anyway, I've looked at the code and there isn't much I can do in this case since it looks like the plugin is running. I don't have a way to test the connections or environment. Best to ask pachube support.
              toto ete
              thanks jim
