    Hiding edges with fill_from_mesh
    13 Posts 2 Posters 1.0k Views 2 Watching
      cjthompson
      Is there any way to hide the triangulated edges in a PolygonMesh when you use either fill_from_mesh or add_faces_from_mesh?
      I noticed that there can be negative indexes in a polygon, but I can't find any way for either method to hide those edges.
        Both got a smooth_flags argument. Is it not working for you? I use fill_from_mesh for my Teapot plugin - smooth edges no problem.
          No, I had weld set to true. Probably why it won't smooth - since you don't weld the edges together.
            cjthompson
            I tried using entities.fill_from_mesh(mesh,false,8) and entities.add_faces_from_mesh(mesh,8). it only works on faces with four or less edges.
            Are these the same arguments that you are using?
              cjthompson
              even when I set weld to true, I still get the triangulation.
              here is an example:
              I start with this. then I use mesh = face.mesh
              but when I try adding the mesh to the entities, it triangulates regardless of the flag setting:
                You only smooth the edges - that does not hide the edges. Only affects the shading of the connected faces. You must Soft the edges, use 4 or 12.
                See this post for screenshot example of what smooth vs soft vs hidden does: http://forums.sketchucation.com/viewtopic.php?f=15&t=23239&p=196887#p196744
                  cjthompson
                  ok. I tried that, but I want to seperate faces that aren't coplanar.
                  Basically, I'm trying to go from a face to a mesh, then back to a face again, so there is no visible difference between the original and the face from the mesh. It sounds like that isn't really possible.
                    hmm... I've not tried to do that...
                    what if... you use the mesh you get from the face as a temporary mesh. Then iterate the polygons in that mesh and recreate a new one - but in the new one you add negative indexes for the edges you want to hide?
                      Are you trying to make a script that triangulates the geometry while making it look the same as the original?
                        cjthompson
                        this script isn't for any use in particular, I'm just trying to get the hang of polygon meshes.
                        the best way to describe what I'm doing is trying to turn all model entities into a mesh, delete the original entities, then put the mesh back, hopefully keeping the original stucture.
                        the problem isn't getting the negative numbers, it's making Sketchup recognize those numbers. it seems to completely ignore them. (if you puts face.mesh.polygons, you can see that there are already negative numbers there).
                          mesh = Geom::PolygonMesh.new #<Geom::PolygonMesh:0xf631898> mesh.add_point [0,0,0] 1 mesh.add_point [100,0,0] 2 mesh.add_point [0,100,0] 3 mesh.add_point [100,100,0] 4 mesh.add_polygon(1,-2,3) 1 mesh.add_polygon(-2,3,4) 2 Sketchup.active_model.active_entities.fill_from_mesh(mesh) true
                          This sample produces two faces where the edge between them is soft.
                          Note that in my example I don't use any smooth_flags argument. I think that the optional smooth_flags argument overrides the negative indexes if you use it.
                          (also, my example is a bit messed up as the two faces have opposite normals.)
                            cjthompson
                            It looks like that's what the problem was. Now I just have to figure out how to combine meshes. 😄
                              That would either be using Entities.add_faces_from_mesh for each mesh - if its ok to merge them in the Entities collection.
                              Otherwise you need to iterate one mesh and add all the polygons to the other.
