    Hollowing an object?
    6 Posts 4 Posters 5.1k Views 4 Watching
      Schorhr
      Hello,
      maybee I was just unable to find something, but I would like to know if there is a tool to make objects "hollow" with a certain wall strength, in order to print them cheaper at Shapeways.
      While for simple forms intersecting them with a smaller version might be sufficient, this will not work with more complex shapes, as the thickness then is not constant or even holes are created...
      Thanks for any help πŸ˜„
      -Marcus
        d12dozr
        Hi Marcus, welcome!
        Maybe the Joint Push Pull plugin by Fredo6 will help you if your faces are curved, otherwise you may be in for a lot of manual work 🀒
        -Marcus
        P.S. I thought I was the only one with that name around here πŸ˜› πŸ˜„
        http://goo.gl/f7ooYh
        • W Offline
          watkins
          If I understand your requirements correctly then what is needed is a 'shell' plugin, but something can still be done with the scale tool. Try something like this
          • select the object (the part you want to shell)
          • copy
          • de-select the object (click outside)
          • use paste in place
          • select the scale tool and use global scale (about the centre) to reduce/increase the size of the copy
          • use other geometry (like cutting planes) to achieve the required geometry
          Some trial and error will be needed to achieve the required wall thickness. For regular shapes, you can input the final dimensions of the bounding box in X, Y and Z in the value control box (eg. 100mm,100mm,100mm)
          Frodo's scale tool might be better as it has more options.
          Perhaps you could post an image of what you are trying to do.
          Regards,
          Bob
            driven
            hi Schorhr,
            there are quite a few useful plugins for SU for Shapeways models
            it can be a minefield going through them all
            post your AE .skp and I'll see which I would suggest
            alumide makes great objects doesn't it
            john
              Schorhr
              Thanks for the offer, driven!
              I think I discovered the errors, but I will just remodel it.
              Also, I was not aware of the follow-me tool back then πŸ˜„
              I have tried a few free plugins such as for rounding edges, and there really is a lot of usefull stuff out there.
              Alumide is great, though it looked differently then I expected. Too bad Shapeways discontinued it for now, but it may be back...
                Schorhr
                Thank you for your quick replies πŸ˜„
                @Watkins
                Yes, a Shelling plugin would be great πŸ˜„
                Skaling will work for cubes for example, but notas soon as there are shapes with curves or such. The walls get different strenghts, and the smaller object might penetrate the walls from the larger object ( http://www.nottoxic.com/wapcc/ae/aqua/curvedresizedsketch.png as a simple sample, but in this particular sample I could just draw a smaller tube).
                I do not have a specific sample as I mostly try to hollow the seperate segments now before 3D printing, but especially when working with existing models it would be neat to have a shelling tool in sketchup.
                A tool like in photo editors such as erode & dilate etc. would be neat.
                @d12dozr
                Hi Marcus, thank you for the welcome.
                I'll look into the push/pull tool, looks like it at least makes the manual process a lot easier πŸ˜„
                Ah well, if it all was so easy that no work was involved, there would be no challange πŸ˜‰
                Fixing "Han Solo in Carbonite" with Sketchup which I found at Thingiverse was a challange though and pure madness.
                http://www.nottoxic.com/wapcc/3dd/alumide/med_P1070972_t.jpg
                http://www.nottoxic.com/wapcc/3dd/alumide/med_P1070974_t.jpg
                There I really just copied and scaled a copy, but had to model and cut a lot manually... As there was a deadline for printing with alumide, I had to rush it a bit.
                http://www.nottoxic.com/wapcc/3dd/alumide/med_P1070974.html
                Similar here;
                http://www.nottoxic.com/wapcc/3dd/alumide/med_P1070978_t.jpg
                http://www.nottoxic.com/wapcc/3dd/alumide/med_P1070979_t.jpg
                Only the flat version printed, I tried to simply scale a copy to make it hollow, but a few parts turned out to be too thin to be printable.
                The initial version should have looked like
                http://www.nottoxic.com/wapcc/ae/aqua/ae3dDone.png
                to replace the stolen car emblem of my GF's car πŸ˜‰
                For square shapes, Sketchup & Shapeways rock my socks though...
                http://www.nottoxic.com/wapcc/3dd/med_P1070957_t.jpg
                http://www.nottoxic.com/wapcc/3dd/med_IMG_3611.html
                This little thing will hopefully fly next week, as soon as the TT Copter Control arives πŸ˜„
