    [CExt] malloc vs ALLOC
    6 Posts 3 Posters 701 Views 3 Watching
    • thomthomT
      http://www.ruby-doc.org/docs/ProgrammingRuby/html/ext_ruby.html#S4
      From that, it appear that Ruby Extension framework provides other methods of allocating memory. ALLOC_N, ALLOC, ALLOCA_N.
      You may sometimes need to allocate memory in an extension that won't be used for object storage---perhaps you've got a giant bitmap for a Bloom filter, or an image, or a whole bunch of little structures that Ruby doesn't use directly.
      In order to work correctly with the garbage collector, you should use the following memory allocation routines. These routines do a little bit more work than the standard malloc. For instance, if ALLOC_N determines that it cannot allocate the desired amount of memory, it will invoke the garbage collector to try to reclaim some space. It will raise a NoMemError if it can't or if the requested amount of memory is invalid.
      Is it that it's preferred to use these methods over malloc? For what purpose would I use these over malloc and free?
      I also found this: http://zed.0xff.me/2010/01/17/you-must-free-memory-you-got-from-alloc-n-and-friends
      You MUST free memory you got from ALLOC_N & friends
      So from the first link I got the impression that using ALLOC would make the GC take care of the data. But this second seem to indicate otherwise - which makes me wonder more on why I would use it.
      I just made a test where I needed to make a dynamic C array to keep some data while doing calculations. I used malloc to create it and call free before I return. Would that be fine?
      • T
        todd burch
        Yes, that would be fine to manage it yourself.
        • tbdT
          tbd
          ALLOC* are just macros that use xmalloc which is a malloc with a if condition for memory exceeded. (I use ALLOC* with free in my code btw)
          SketchUp Ruby Consultant | Podium 1.x developer
          http://plugins.ro
          • thomthomT
            ALLOC* are safer than malloc? Better practice?
            • tbdT
              tbd
              safer IMHO. also easier on the eye in the source code.
              http://plugins.ro
              • thomthomT
                ALLOCA_N
                Allocates memory for n objects of c-type on the stack---this memory will be automatically freed when the function that invokes ALLOCA_N returns.
                Does that mean one does not need free the memory allocated by this variant? Are there times one can not rely on it?
