    Untrapped Error
    5 Posts 3 Posters 402 Views 3 Watching
      MartinRinehart
      I'm writing a console. You input 2+2 and it outputs 2+2 # 4. Problem is, your input may not be perfect, so a little error trapping is needed.
      In this part of the process() function (line #s added):
      59    results = []
      60    for line in lines do
      61        rslt = line.chomp() + ' # '
      62        begin
      63            rslt += eval(line).to_s().chomp()
      64        rescue => e
      65            rslt += e.to_s().chomp()
      66        end
      67
      68        results.push( qq(rslt) )
      69    end # loop over lines
      I'm thinking that an error at line 63 gets caught and reported at line 65. It usually does. Now, however, I've got this:
      Any ideas why this isn't caught by the rescue statement? Any ideas on how to catch it?
      Author, Edges to Rubies - The Complete SketchUp Tutorial at http://www.MartinRinehart.com/models/tutorial.
        todd burch
        From the Pickaxe Book: (Ruby 1.8, page 110)
        "If you write a rescue clause with no clause parameter list, the parameter defaults to StandardError"
        You got a SyntaxError, which is part of ScriptError, not StandardError.
        Try this:
        rescue Exception => e
        to catch everything.
          MartinRinehart
          I don't want to seem ungrateful, but that upgraded me to Bug Splat. Is there a
          rescue BugSplat => e
            todd burch
            Do you have access to the pickaxe book? Try ScriptError. Try a stepladder of all the exception subclasses with multiple rescues.
            • Dan RathbunD Offline
              Dan Rathbun
              @martinrinehart said:
              > 64  rescue => e
              > 66  end
              Your local reference e receives a pointer to an Exception object from the rescue clause, not a String object.
              You should use the instance method Exception.message to get the exception's string, like this:
              65 rslt << e.message.chomp()
              (As a side-note on Optimization, generally speaking, + and += String concatenation, require Ruby to create at least one extra String object than String append <<. Ruby internally converts a+=b to a=a+b, OR a+='literal' to a=a+'literal', so using += doesn't gain you anything over <<, and may be twice as slow or more, in a loop.)
              I'm not here much anymore.
