    Loading Ruby Scripts
    6 Posts 4 Posters 1.3k Views 4 Watching
    • M
      madcadder2007
      Having trouble Loading Ruby Scripts, Recently Download few Scripts copy them to my C:\Program Files\Google\Google SketchUp 7\Plugins folder. when i start Skecthup i donot see scripts i copy just the ruby scripts i had before.am i doing something wrong.
      • Chris FullmerC
        Well, from what you described you are doing nothing wrong.
        But if you don't have any scripts showing up, then obviously something is going wrong. But you will need to explain in better detail to be able to get detailed help.
        What scripts? Did you try starting with just one script? Are these scripts that you have used before? Have ever succesfully installed a script? etc,
        Chris
        All my Plugins I've written
        • M
          madcadder2007
          Chris
          Did successfully install (2) Ruby Scripts Weld.rb Simplfliy contours.rb try to install deletecoplanaredges.rb not showing in Plugins pull down menu.
          • mitcorbM
            mitcorb
            Did you by chance accidentally grab a file with a php extension, instead of the rb or zip extension? This has happened to me occasionally. Before the page is fully loaded where the target link is displayed, you can "right click save link as" too soon and send a php entity to your destination folder. php's don't do anything.
            Just a thought. Not necessarily the answer to your concern.
            • D
              d12dozr
              Plugins do not have to appear under Plugins menu, they can show up in Right click menu, Tools menu, and Draw menu. I'm not familiar with deletecoplanaredges.rb, but I would check in those places I mentioned first...
              http://goo.gl/f7ooYh
              • M
                madcadder2007
                Found it, it was Right Click Menu.
                Thanks for the Help
