    View.draw2d and AA - precision
    12 Posts 2 Posters 863 Views 2 Watching
    • thomthomT
      While experimenting with view.draw2d I noticed a couple of things:
      When drawing lines of odd width one must offset the X and Y coords by 0.5 in order to maintain a sharp line. The coords must be on the centre of the line, even if the pixel coords contains half a pixel.
      For even width one must use whole values.
      Notice that the corner never is sharp when drawing with GL_LINE_LOOP.
      GL_LINE_LOOP - 9px width
      Then you have the drawing of points:
      When AA is on - the points become drawn fuzzy. Even if you offset. There does not appear to be a way by using the SU Ruby API to draw sharp 1px points. (Using GL_POINTS)
      No offset - Integer co-ord values
      Co-ords offset by .5
      When AA is off, then the 1px points appear sharp and in exactly the colour one specify.
      No AA
      I really wish there was a way I could draw 1px points - sharp - without the AA fuzzing it up. I'd appreciate if anyone has any ideas. Or even some insight to how OpenGL treats screen coordinates.
      • thomthomT
        See how the pixel is blurred no matter what? 😞
        • thomthomT
          I just noticed that ATI cars, while they don't draw points where the X and Y is whole numbers, they do draw the pixel sharply.
          The first set of icons are drawn with GL_POINTS - same method the turned blurred on nVidia.
          The second set is pixels drawn with GL_LINES - which is slower, but draws sharply on both nVidia and ATI.
          If only I could detect the make and AA settings of SU from Ruby...
          GL_POINTS vs GL_LINES - ATI Radeon HD 4870 X2
          • Chris FullmerC
            I can confirm that the ATI machine I am on draws sharp edges always. On some stuff I've been working on, my nVidia card draws fuzzy edges, but this ATI mcahine is drawing those same edges as sharp.
            Chris
            All my Plugins I've written
            • thomthomT
              All edges?
              • Chris FullmerC
                It is the edges around my gradient boxes that are coming out as sharp on this machine. I am not drawing any single pixels anymore at this point. So yeah, just edges. But they definietly come out different than they do on my nvidia card at home.
                Chris
                • thomthomT
                  Chris
                  Even if they are not offset 0.5?
                  See my last screenshot - the top rectangle is 1px with whole number values. It's fuzzy. (not as fuzzy as on nVidia - but the colour is fainter.) The next one, is offset 0.5.
                  What cards have you tried? And what OS?
                  • Chris FullmerC
                    it is an 128mb ATI Radeon X600 SE on Win XP.
                    It appears to be drawing a solid single pixel line. But I have no screen capture utility or anything like photoshop to magnify and inspect the line work. After work tonight I'll install jing and get a good screen capture shoing what it looks like, then you can decide what it really is doing.
                    Chris
                    • Chris FullmerC
                      And I see that there is no AA turned on in SU (or when I got to the Preference > OPEN_GL tab is says aa=0x)
                      • thomthomT
                        Ah! No AA. Does it not have any AA option?
                        video? is it not easier to just PrntScrn?
                        • Chris FullmerC
                          Jimg makes great .png screen captures and saves them to the desktop. Lets you specify a window size, etc. Add comments, arrows and lines on it afterwards.
                          For prntscrn, I don't have any app I can paste it into and edit it on this computer. Its like the stone age of computers in this house I'm staying at πŸ˜„
                          No, there was no option avaiable to turn on aa. Maybe I can do it through the video card first? And then it might be available in SU? This is an area I never get into because I have never really cared about how smooth the detail is on my games πŸ˜„ But maybe I should figure it out since it also pertains to SketchUp.
                          Chris
                          • thomthomT
                            hmm... I can use the SU preferences to detect the AA settings of SU. On Windows it's under GLConfig > Display. Then I need to locate that on OSX.
                            Only thing is that reading registry requires more files and makes for more complicated dependabilities.
                            And I don't get the make of the card from SU's prefs... πŸ˜•
