    Reset All Face UV's in a selection
    4 Posts 2 Posters 959 Views 2 Watching
      dburdick
      Like the title says... is this possible? I don't see anything in the Ruby api that will reset UV's although there is the send_command 21516 Reset original texture position. But I don't see a select method that would allow me to select a face by cycling through a selection list. Hard to beleive that the standard Sketchup does not allow a Texture Reset Position from a section of faces instead of just a single face. Any ideas?
        model = Sketchup.active_model
        sel = model.selection
        cache_selection = sel.to_a
        cache_selection.each { |e|
        	sel.clear
        	sel.add(e)
        	Sketchup.send_action(21516)
        sel.clear
        sel.add(cache_selection)
        But Sketchup.send_action(21516) does not appear to work.
          Not greatly tested, but this looks to position the texture as it where reset
          face.position_material(face.material, [ ORIGIN, [0,0,0] ], true) face.position_material(face.back_material, [ ORIGIN, [0,0,0] ], false)
            dburdick
            TT to the rescue again. Many thanks. I tried it the first way as well but found the send_action call didn't work either. Your second method works like a champ. You're a star.
