    Morality
    8 Posts 6 Posters 518 Views 6 Watching
      remus
      A question for the collective SCF conciousness:
      Would it be immoral to use the universities computing cluster, described as such:
      A 160-node 64-bit Itanium cluster supplied by Bull.
      lynx consists of 20 compute nodes, each having four dual-core Itanium 1.6GHz CPUs and 16GB of main memory. The compute nodes are connected by a Quadrics network.
      lynx is running Bull Linux AS4 V5.1, a modified version of Red Hat Linux AS4.
      There is approximately 10TB of disc area available for users.
      to render a scene or 2 with luxrender?
      I can almost taste the 256 GHZ of processing power. πŸ˜„
        Marian
        Why would it be immoral? ❓
        If you are not making 3d porn with it, I say go for it.
          david_h
          If its concentual. . . ..
          Are you forcing the computer against its will? Then yes. . .it's wrong. πŸ’š
            dermotcoll
            It would be immoral not to!!!!
            I would get the knarliest model with a huge face count and let rip to see just how good the system is - then you'll know the level of output you can look forward to in the future!!
            When you burn your arse - you gotta sit on the blisters!!
              remus
              Thats what i like to hear πŸ˜„
              Marian, it was a thinly veiled attempt to shoe horn my favourite subject of render farms in to a thread.
                Jackson
                ... that would be an awesome render farm and yet with all that power SU would still only run at 1.6GHz. Where's a "head in hands" smiley when you need one?
                I imagine that V-Ray would be close to running real-time 30fps photorealistic rendering on that bad boy..... droool.
                Jackson
                  remus
                  Its a linux box (albeit a big one) so quite limited in what software would run on it. I imagine lux should give me some options, though πŸ˜„
                    solo
                    Imagine running Thea on it.... sweetness.
                    Thea runs on Linux.
                    http://www.solos-art.com
