    Optimization Tips
    110 Posts 22 Posters 175.3k Views 22 Watching
      cjthompson
      Has anyone looked into Enumerable.grep()? it seems pretty useful, but I don't know how fast it is.
        Jim
        @adamb said:
        @jim said:
        I guess to get back on topic, for loops are not faster then .each iterators. The performance must have to do with how the for loop variables are not loop scoped, as in each.
        "Your racing car is not faster than my Trabant, it just covers more ground in a shorter time than my car." πŸ˜„
        Heh? Oh. Yes, I see. 😳
        Would it be correct to say: An each loop can be as fast as a for loop if the loop variable has been initialized?
          That would mean it's not the each loop itself that's slow - but the creation of variables.
            Jim
            Exactly.
              Vertex.position is slow! Cache the result if you need to use the same Point3d multiple times.
              Point3d.distance also accepts Vertex objects in place of Point3d or Array.
              point1.distance(vertex2) is faster than point1.distance(vertex2.position).
              Sketchup Vertex.position speed performance - ThomThom's Website
              (www.thomthom.net)
              • AdamBA Offline
                AdamB
                Its all interesting info you're digging up thomthom, but I wonder where you're going..
                Ruby is a scripting language that makes for very quick development, modern constructs and good readability. So you pay for that with execution performance. However, performance with a big P which may include how fast you can complete and deliver functionality may be better - but once again I do think you should play to Ruby's strength rather than perhaps bend it into something it isn't.
                By the time you've created local copies of state, rewritten everything using a compact form etc etc you end up with something that is less readable and probably more prone to bugs. And as you've discovered, there is a massive difference in performance between native code and Ruby - such a large gulf, you're never going to come even close to closing it.
                You should do heavy lifting with a C extension and GUI / API / semantic stuff with Ruby. Processing geometry topology with Ruby is, in general, not practical. Not that it can't be done..but that's not what I'm suggesting.
                  That was actually stuff I found out before I got around to do a C extension.
                  Jumping from Ruby - or any other scripting language - C extensions is not an easy jump. If C isn't your cup of tea then it's worth knowing what saves time in Ruby. Most plugin writers here doesn't do C and have no interest in it either. Just making something that work - but still one can save noticeable time.
                  What I found most interesting in those test was that Vertex is a valid argument where the manual claims only Point3d. And passing the Vertex is faster than Vertex.position.
                  As for C extensions - it appear that there's a significant overhead of converting VALUEs to workable C types - so if you iterate only once over a set of data there isn't much to gain. Only if there's quite a bit more calculations.
                  • AdamBA Offline
                    AdamB
                    Not really. You asked the wrong question, so you perhaps got an answer that has misled you.
                    You asked about converting Ruby arrays to C etc. And everything I said stands. However, sounds like you actually want a C extension that operates upon the Ruby structures. If you have a situation where you are just wanting to twiddle existing Ruby data from C, it is well worth doing even for 1 pass because the fixed costs are pretty much zero.
                      I'm very green to this Ruby <-> C interaction - so its very likely I'm not doing thing the right way around.
                      What I have done so far is to calculate the soft selection for my Vertex Edit. So for each vertex in the selection set I needed to find the closest closest distance to any of the vertices not selected. It was the distance method that was so slow.
                      I did some tests - created a dummy set of 3d data in C and calculated the soft selection for that. Very fast. But as soon as I made the source data set come from RUBY it became very slow. The C function was setting two sets of ruby arrays of vertices. Getting the X,Y,Z data for each vertex seemed to be very slow - converting Vertex to Point3d and then converting the X,Y,Z into C doubles.
                      For every vertex in the selection I was iterating the remaining set of vertices and converting them.
                      What I then did was to do a pre-pass of the non-selected vertices and create an C array of point3d structs. I then got a big speed increase. That's what lead me to the impression that converting Ruby VALUES to C types are expensive.
                      • AdamBA Offline
                        AdamB
                        distance requires a square root of a scalar product. ie sqrt(A.B)
                        Keep in mind that in native "cpu" math, A.B is perhaps ~5 cycles and sqrt(X) is perhaps ~35 cycles. If you don't actually need the squareroot but just need to find the closest, then just compare A.B which should be significantly faster.
                          Yes - I was reading up on sqrt and found that to compare "longer" and "shorter" I didn't need sqrt. So I changed my code to only do the square root after I've found the shortest distance. That way it's called only once per vertex in Selection. (I needed the distance for some other calculations)
                            cjthompson
                            well, since no one seems to be listening... 😒
                            I ran my own test (for: is using a for loop, grep: is using Enumerable.grep)
                            speedTest for: entities - 0.016 grep: entities - 0.015 for: entities array - 0.0 grep: entities array - 0.016 for: range - 0.219 grep: range - 0.203 for: range array - 0.219 grep: range array - 0.218 for: strings - 0.469 grep: strings - 0.234 nil
                            here is the code I used:
                            def speedTest
                            	entities = Sketchup.active_model.entities
                            	entitiesArray = entities.to_a
                            	range = 0..1000000
                            	rangeArray = range.to_a
                            	strings = range.collect{|number| number.to_s}
                            	## Entities
                            	results = []
                            	start = Time.now
                            	for ent in entities
                            		if(ent.class == Sketchup;;Edge)
                            			results << ent
                            	puts "for; entities - " + (Time.now - start).to_s
                            	results = []
                            	start = Time.now
                            	results = entities.grep(Sketchup;;Edge)
                            	puts "grep; entities - " + (Time.now - start).to_s
                            	## Entities array
                            	results = []
                            	start = Time.now
                            	for ent in entitiesArray
                            			results << ent
                            	puts "for; entities array - " + (Time.now - start).to_s
                            	results = []
                            	start = Time.now
                            	results = entitiesArray.grep(Sketchup;;Edge)
                            	puts "grep; entities array - " + (Time.now - start).to_s
                            	## Range
                            	results = []
                            	start = Time.now
                            	for num in range
                            		if(num == 318256)
                            			results << num
                            	puts "for; range - " + (Time.now - start).to_s
                            	results = []
                            	start = Time.now
                            	results = range.grep(318256)
                            	puts "grep; range - " + (Time.now - start).to_s
                            	## Range Array
                            	results = []
                            	start = Time.now
                            	for num in rangeArray
                            		if(num == 318256)
                            			results << num
                            	puts "for; range array - " + (Time.now - start).to_s
                            	results = []
                            	start = Time.now
                            	results = rangeArray.grep(318256)
                            	puts "grep; range array - " + (Time.now - start).to_s
                            	## Strings
                            	results = []
                            	start = Time.now
                            	for str in strings
                            		if(str.match(/312\Z/))
                            			results << str
                            	puts "for; strings - " + (Time.now - start).to_s
                            	results = []
                            	start = Time.now
                            	results = range.grep(/312\Z/)
                            	puts "grep; strings - " + (Time.now - start).to_s
                            and the model I tested on:
                            test1k.skp
                              I also read that depending on the settings of the compiler the instruction set used to compute sqrt and it's performance vary greatly. One of the articles I read suggested that many compilers will use old set of instructions by default for greater compatibility.
                              What do you do for your projects?
                              Edit: one of the articles I read: http://assemblyrequired.crashworks.org/2009/10/16/timing-square-root/
                              • P Offline
                                Pout
                                concerning typename vs class:
                                For, till now, unexplained reason when i change typename with class the results are different
                                Script is a bit like this:
                                x=entity.class (or entity.typename)
                                if x=="Face"
                                do something
                                elsif x=="Group"
                                do something
                                elsif x=="ComponentInstance"
                                do something
                                else
                                When the type is "ComponentInstance" the results are not the same for class and typename.
                                I need to check on this since the speed increase is huge
                                  .class returns a Class object - not a string.
                                  What causes the slow down is the string comparison - that's what you want to avoid.
                                  x=entity.class
                                  if x==Sketchup;;Face
                                    do something
                                  elsif x==Sketchup;;Group
                                    do something
                                  elsif x==Sketchup;;ComponentInstance
                                    do something
                                  else
                                  or
                                  if entity.is_a?(Sketchup;;Face)
                                    do something
                                  elsif entity.is_a?(Sketchup;;Group)
                                    do something
                                  elsif entity.is_a?(Sketchup;;ComponentInstance)
                                    do something
                                  else
                                  Update: fixed is_? to is_a?
                                  • P Offline
                                    Pout
                                    I'll check and let you know. When i use 'class' the correct conditions are entered but the result differs.
                                    I'll keep you posted if it changes with your scripts.
                                    Thx
                                    • P Offline
                                      Pout
                                      all works, speeds increase is fine πŸ˜„
                                      thx!
                                        πŸ‘
                                        • K Offline
                                          kwalkerman
                                          One thing I have noticed is that some code runs much slower with the outliner window open. Is there a way to close the window at the start of certain code execution, and then re-open it at the end?
                                          Karen
                                          • Dan RathbunD Offline
                                            Dan Rathbun
                                            Maybe...
                                            but have you tried using Model.start_operation ?
                                            see also abort_operation and commit_operation
                                            I'm not here much anymore.
                                            • 6
                                            • 3 / 6
