    Optimization Tips
    110 Posts 22 Posters 191.0k Views 22 Watching
    • AdamBA Offline
      AdamB
      @thomthom said:
      Didn't realise Ruby would recreate the variables for each iteration. I'd thought it'd keep them for the duration of the loop...
      The closure you create with curly braces is handled as a first class object and passed as an argument to the iterator. This means the scope of any variables you mention inside that block is limited to that block - it must create them each time. 😞
        Is that why each is slow?
          Guys, Thom asked if we can do something with these white spaces but I have to say it is most probable that we cannot. I is hard coded somewhere in the php script of the forum software and even if we could tweak that, it would be impossible to keep it through upgrades (which is very due soon anyway).
          Is the code tag not good (apart from that scrolling annoyance)?
            It's ok. I just hoped there was a config UI for BBCode tags on the forum. Thought it was normal. The code tag is ok, just figured if it could be changed...
            I don't suppose there are forum plugins that can be installed? having the code block apply syntax highlighting would be a delight for us coders. Such as this:
            Google Code Archive - Long-term storage for Google Code Project Hosting.
            (code.google.com)
            http://syntaxhighlighter.googlecode.com/files/Overview01.png
            Edit: what version of phpBB does SCF run? I'm looking at this: http://www.phpbb.com/kb/article/adding-custom-bbcodes-in-phpbb3/ from this it appear to be that it'd be a matter of setting the HTML replacement for the ruby tag to not collapse white space using CSS.
            Replacement sample something like this:
            <span style="white-space:pre;">{TEXT}</span>
              I can imagine you would like that syntax highlight! I use Notepad++ and know what a difference it is!
              Coen and Tavi should be spoken to about these things.
                @adamb said:
                I see a lot of SU scripts using some of the more compact iterators Ruby iterators. So they might read nice, but they're often slower than just simple for-loops.
                403 Forbidden
                (blog.shingara.fr)
                In regard to this should one init the variables used by for in to speed up things? or is that not needed?
                Would this
                ` x = 0
                for x in collection
                endbe faster than for x in collection
                end`
                • AdamBA Offline
                  AdamB
                  no
                    Jim
                    I've always thought for used each under the hood.
                    http://blog.grayproductions.net/articles/the_evils_of_the_for_loop
                    for loops do not have their own scope - the loop variable and any variables created in the loop become available (or are over-written) in the current scope.
                    With .each, variables are local to the block {..}
                      If you click the method names in the Ruby API manual you get to see the sourcecode:
                      http://ruby-doc.org/core/classes/Array.html#M002173
                        Jim
                        That's showing a for loop in the c language.
                          That's what it's doing under the hood.
                            Jim
                            Right, so where is the definition for the for function?
                            The answer is there isn't one because for is not a function, but is "sugar". The for loop in Ruby really uses the .each method behind the scenes.
                            Although, I can't recall where I learned that. The link to the blog article mentions it, though.
                            • tbdT Offline
                              tbd
                              speaking of each vs for :
                              loop1 = []
                              loop2 = []
                              calls = ["one", "two", "three"]
                              calls.each do |c|
                                loop1 << Proc.new { puts c }
                              for c in calls
                                loop2 << Proc.new { puts c }
                              loop1[1].call #=> "two"
                              loop2[1].call #=> "three"
                              SketchUp Ruby Consultant | Podium 1.x developer
                              http://plugins.ro
                              • Dan RathbunD Offline
                                Dan Rathbun
                                @jim said:
                                The for loop in Ruby really uses the .each method behind the scenes. ... Although, I can't recall where I learned that.
                                'Pick-Axe' > For ... In expressions
                                I'm not here much anymore.
                                  Jim
                                  I guess to get back on topic, for loops are not faster then .each iterators. The performance must have to do with how the for loop variables are not loop scoped, as in each.
                                    Came across this link:
                                    http://www.h3rald.com/articles/efficient-ruby-code-shortcut-review/
                                    On that list it says
                                    Use parallel assignment (a, b = 5, 6) where applicable
                                    while at this link:
                                    http://www.hxa.name/articles/content/ruby-speed-guide_hxa7241_2007.html
                                    Avoid parallel assignment
                                    πŸ˜’
                                      while at this link:
                                      πŸ˜’
                                      I just bought the ebook and that review summary was wrong - parallel assignments are not recommended for performance important tasks.
                                      Interesting read that book btw.
                                        MartinRinehart
                                        Let's see - for performance I'm going to avoid iterations, arrays, hashes and objects.
                                        What's left?
                                        Author, Edges to Rubies - The Complete SketchUp Tutorial at http://www.MartinRinehart.com/models/tutorial.
                                          @martinrinehart said:
                                          What's left?
                                          puts "Hello World" πŸ˜„
                                          • AdamBA Offline
                                            AdamB
                                            "Your racing car is not faster than my Trabant, it just covers more ground in a shorter time than my car." πŸ˜„
                                            • 6
                                            • 2 / 6
