    Create group
    4 Posts 3 Posters 407 Views 3 Watching
    • P Offline
      Pauline01
      hello,
      I create an entitie with a plugin but i don't arrive create a group with each point of my entitie...
      require 'sketchup.rb'
      def add_etiquette
        # Get "handles" to our model and the Entities collection it contains.
        model = Sketchup.active_model
        entities = model.entities
        # Create a series of "points", each a 3-item array containing x, y, and z.
        pt1 = [0, 0, 0]
        pt2 = [30, 0, 0]
        pt3 = [30, 0, 17]
        pt4 = [0, 0, 17]
        # Call methods on the Entities collection to draw stuff.
        new_face = entities.add_face pt1, pt2, pt3, pt4
        ##here i want create a group of "new_face"(in sketchup it's a selection right click and make group).
        ##How do in ruby?
      #Menu
      if (not file_loaded?("zEtiquette_config.rb"))
          tool_menu = UI.menu "Tools"
      	tool_menu.add_item("Create zone item") {
         add_etiquette
      	$VSX = Vsx.new
        file_loaded("zEtiquette_config.rb")
        Create the group before you create the face.
          pt1 = [0, 0, 0]
          pt2 = [30, 0, 0]
          pt3 = [30, 0, 17]
          pt4 = [0, 0, 17]
          # Create group to contain entities
          group = entities.add_group
          # Call methods on the Group's entitites collection to draw stuff.
          new_face = group.entities.add_face(pt1, pt2, pt3, pt4)
        It's a bit different from when you model in SU where you first draw your entities, then group. When you write ruby scripts, it's best to create the group first, then add the entities inside that group.
          remus
          something like this should do it:
          group = entities.add_group group.entities.add_face(pt1,pt2,pt3,pt4)
          Basically all your doing is creating a group then adding your face to the list of entities contained within the group. Because of this you can remove the entities.add_face in your original code.
          • P Offline
            Pauline01
            oh, ok.... it's simple. thx guys
