    Programming in C, C++ for Mac and Windows?
    51 Posts 9 Posters 9.4k Views 9 Watching
    • Chris FullmerC Offline
      Sorry to get everyone so riled up around here. Lets not be bashful, dig out those old skeletons from the cloest.....oh wait, we already are!
      The point of this thread is in fact SU based, and about how to write extensions for SU ruby. Or how to interface into SU from another program, or dll, etc. I really am not sure what my question is because I just don't know what is possible, and I don't have a specific task in mind that I am striving to find a solution for (yet!). I just want to broaden my horizons and I want to do it with a compiled language.
      But I will say that I have installed a few compilers and such and I am reading up on C++ currently. But it gives a bit of background into C, C# and Java. Hopefully I'll be able to wrap my head around it.
      Chris
      All my Plugins I've written
        toxicvoxel
        @adamb said:
        The thread is about producing Extensions for Ruby (which is written in C).
        Really? I thought the opening line of the starter post was related to interfacing SU with external .dll's - which can be written with a variety of languages. Seen within that broader premise I think the comments would be misleading to novices looking for an unbiased opinion about selecting a language.
        It's all well saying Mono, but the reality is that on a Mac, Xcode has great support for C/C++ and not Mono/C#.
        You may notice that my response was in context with the statement that .NET code cannot run cross platform, so I am at a loss to understand the logic of your point. Does XCode run on Windows platforms yet?, - I didn't know, nor does it matter as my design workflow is Windows based.
        TBD, not sure what you want to know.- I have written a number of external .dlls that I interface with from Sketchup as part of my daily workflow, so I can assure you that it is possible, if you are suggesting that it can't be done.
          toxicvoxel
          and I am reading up on C++ currently.. But it gives a bit of background into C, C# and Java
          That may take some time... πŸ˜‰
            toxicvoxel
            A positive idea that can be spun off from this thread would be to create a 'Ruby extendibily' subsection where developers could post sample 'How To..' code for linking SU to external applications, libraries, databases & web-services etc., through native extensions, Win32API, WIN32OLE, file IO, SOAP, and custom bridges etc. For example : Linking SU to Excel, SQL databases, XML, text files, connecting to a web services, linking to CAD. etc
            Starter code for interaction of SU Ruby with external libraries created with the plethora of languages in use could be posted over time by coders proficient in those languages. Such a code repository would be invaluable to existing developers proficient in other languages who wish to use Ruby to glue Sketchup to existing code and applications. This could also serve as a catalyst for seeing more plugins and extensions becoming available over time.
            [- And for novices the sample code could help to inform a choice for selection of a supporting coding language.)
              I think that is a neat idea. If I ever make something usef-able I will post it. It looks to be a long ways off at the rate I am moving, but all things are possible. πŸ˜„
              Chris
                toxicvoxel
                A summary of this topic should go onto that list for example:
                http://forums.sketchucation.com/viewtopic.php?f=180&t=25233
                  I am extremely green to C/C++.
                  Currently doing some very basic tests in C++ with VS2010.
                  There is some number crunching that I'd like to do in C++. I did some comparisons and the Ruby version was 100 slower than the C++ version. So I am very interested in finding a way where I can create a set of number crushing methods in C++ which I can call from SU Ruby.
                  What I am looking at at the moment is:
                  • Sending two arrays of 3D co-ordinates to the C++ method (3D points can be simple array of three floats)
                  • Have the C++ method do its thing
                  • return a new array back to ruby
                  Does it simplify much if the C++ never have to access any SU objects? Is it then possible to create a Windows and OSX solution? Would it be a DLL on Windows and ... what does OSX use...?
                  The SUExt link in TDB's post (http://forums.sketchucation.com/viewtopic.php?f=180&t=25201#p216233) leads to a wiki page... ❓
                  • tbdT Offline
                    tbd
                    1. see remus response
                    2. PellesC is my favourite - small, fast, free, doesn't install in all your machine, comes with all tools needed. it is C99 compliant
                    I went via VStudio only when I complied some SU SDK programs - too many VS dependent crap to convert it to another compiler
                    1. you need a compiler that creates Mac binaries and PellesC is not one of them 😞
                      but on Mac you have IDE, compiler, debugging tools, Ruby by default so get one.
                    my suggestion:
                    • get a Mac - you can install Windows in bootcamp or virtualized if you want it
                    • start with C, it is easier to debug ruby libraries problems (there are a lot, see Adam's comments)
                    • compile my SUExt example and play with it for start
                    SketchUp Ruby Consultant | Podium 1.x developer
                    http://plugins.ro
                    • tbdT Offline
                      tbd
                      link updated in my original post to http://github.com/TBD/OpenSUP/tree/master/SUExt/
                      http://plugins.ro
                        cheers.
                        Can one download from one branch? I only managed to find a download for the whole lot. (not that it was a big download - just curious)
                        Also - is that extension one that integrates with SU such that you can access SU objects from C?
                        • tbdT Offline
                          tbd
                          nope. only if I create the .zip myself and add them to Downloads tabs.
                          is that extension that only extends Ruby with C code (so the title is a bit misleading for now). you can access SU objects via normal Ruby commands (rb_ functions)
                          http://plugins.ro
                            Would the code be simpler if it didn't integrate Ruby?
                            If it only passed data back and forth? Or is it required to integrate in order to share the various data types?
                            • tbdT Offline
                              tbd
                              you dont integrate Ruby, just the needed headers for Ruby types. as you can see the output .so is small, 10kb, without any size optimizations.
                              you only pass data back and forth.
                              http://plugins.ro
                                And what about Classes defined by SketchUp? How does one handle them?
                                • tbdT Offline
                                  tbd
                                  you can use rb_funcallX (see Ruby Interpretor Interface) to call methods from the classes or you can use array/hashes to pass data
                                  http://plugins.ro
                                    Say I got a collection of Point3d, Vector3d. Would it be best to convert those to arrays of basic numbers in Ruby and passing onto C? Or would it really not matter?
                                    static VALUE test(VALUE vector)
                                      VALUE arr;
                                      arr = rb_funcall(vector, rb_intern("to_a"), 0)
                                    This would leave me with arr being an Ruby Array representing the vector, right?
                                    I see there are rb_each and rb_iterate - should one use ruby iterators to loop through Ruby Arrays in C? Or can one use regular C loops?
                                    Are there further reading than this page: http://www.ruby-doc.org/docs/ProgrammingRuby/html/ext_ruby.html
                                    • tbdT Offline
                                      tbd
                                      right
                                      definitely rb_ functions as you are manipulating an array of pointers (VALUE objects)
                                      http://plugins.ro
                                        I am confused again now. I got Pellets. And I did what the article said about generating a makefile. But I'm confused to how I compile it.
                                        From what I understand, make is a UNIX command?
                                          Ok, getting close I think, - from the Pelles C Project options I added C:\Ruby\lib\ruby\1.8\i386-mswin32 to the includes path.
                                          But now I get:
                                          Building helloworld.obj. C:\Ruby\lib\ruby\1.8\i386-mswin32\config.h(2): fatal error #1014: #error: MSC version unmatch. *** Error code: 1 *** Done.
                                            Pelles crashed on me - and I swear I heard Homer Simpson's "doh!" as it crashed... 😲 πŸ˜†
                                            • 2 / 3
