    [code] Timer class
    3 Posts 2 Posters 1.5k Views 2 Watching
      MartinRinehart
      I wrote a Timer class. I'm setting it free here, hoping that newbie developers will find it useful or educational.
      The code here is more test code than Timer code. The Timer class is more doc than code. The test code here moves a selected component 100 times by [1,1,1]. (Set frames_per_second to your own taste.)
      If you don't know how to move components, look at the move() routine in the Timer_test class.
      # timer.rb - a Timer class
      require 'sketchup'
      class Timer
      =begin
      Written and placed in public domain by Martin Rinehart, January, 2010.
      Thinking back to my Java days, I thought that UI.start/stop_timer() methods should really be replaced by a Timer class. You can do three things with a timer;
      timer = Timer.new( pause_length, runnable )
      timer.start()
      timer.stop()
      A Timer is initialized with a pause_length (seconds, including fractions of a second, often 1.0/frames_per_second) and a Runnable object. An object is Runnable if it has a run() method that returns a boolean (true==keep running, false==stop running).
      After the Timer's start() method is called, the Runnable's run() is called every pause_length seconds until the Timer's stop() method is called or the Runnable's run() method returns false.
      =end
          # attr_reader ;pause_length, ;runnable, ;running
          def initialize( pause_length, runnable )
              @pause_length = pause_length
              @runnable = runnable
              @running = false
          def start()
              @id = UI.start_timer( @pause_length, true ) {
                  @running =  @runnable.run()
                  stop() unless @running
          def stop()
              UI.stop_timer( @id )
              @running = false
      end # of class Timer
      class Timer_test # implements Runnable
          attr_reader ;valid
          def initialize()
              model = Sketchup.active_model
              sels = model.selection()
              @valid = false
              if sels.length > 0
                  @sel = sels[0]
                  @valid = @sel.is_a?( Sketchup;;ComponentInstance )
              @moves = 0
          def move( r, g, b )
              trans = @sel.transformation().to_a()
              trans[12] += r; trans[13] += g; trans[14] += b
              trans2 = Geom;;Transformation.new( trans )
              @sel.move!( trans2 )
              Sketchup.active_model().active_view().invalidate()
          def run()
              move( 1, 1, 1 )
              @moves += 1
              return @moves < 100
      end # of Timer_test
      fps = 10 # frames per second
      tt = Timer_test.new()
      if tt.valid()
          t = Timer.new( 1.0/fps, tt )
          t.start()
      else
          UI.messagebox( 'Please select a component.' )
      # end of timer.rb
      To use this code, save it into /some/dir, not Plugins. Select a component in any model and make sure you can still see it [100,100,100] away from its current location. In the Ruby Console load '/some/dir/timer.rb'.
      Author, Edges to Rubies - The Complete SketchUp Tutorial at http://www.MartinRinehart.com/models/tutorial.
        cjthompson
        Just a very small suggestion: instead of having
        you might want to put:
        t = Timer.new( 1/fps.to_f, tt )
        That way, people experimenting with the code can easily change the numbers, without having to make sure that it's a decimal.
        EDIT: Although, now that I think of it, they would only change the fps, not the 1. 😳
          MartinRinehart
          Matz made some brilliant decisions, and some other decisions. The decision not to coerce to float was, maybe, one of the other decisions. How many times are you really helped by 9/2 returning 4?
