    Md5 encoding in sketchup
    8 Posts 4 Posters 1.3k Views 4 Watching
    • schorradtS Offline
      schorradt
      Hello,
      I need a function to a string md5 encoded within Ruby Sketchup.
      Can someone help me?
      http://www.henryschorradt.de/
        Think you need to copy the md5 methods from a full Ruby 1.8.0 package. Should be located under digest/md5
          schorradt
          I have the digest.so and md5.so placed in the to the plugins directory.
          I try it with
          require 'digest'
          but i get an errormessage:
          Error Loading File mx_eftools.rb
          uninitialized constant MX_eftools::Eftool
          Does it ever so? or I do something wrong?
          The .so-files come from the following package: \ruby-1.9.1-P376-i386-mswin32.zip\lib\ruby\1.9.1\i386-mswin32\
            I'd recommend matching the package in SU, which is Ruby 1.8.0. Look in the old repositories.
              schorradt
              thx... it works πŸ˜„
              but its not easy to get an old version of ruby...
              oldversion.com is goood πŸ˜„
                Think I got mine from http://www.oldapps.com/Ruby.php?old_ruby=12
                  deathangel67300
                  Hello
                  I'm also trying to use a md5 hash in sketchup, but I can't find the good code to do it.
                  I copied the digest.so and md5.so files in the sketchup plugin directory.
                  Than I tried the following code :
                  require 'digest'
                  Digest;;MD5.hexdigest("Hello World\n")
                  and the ruby console displays me the following error : uninitialized constant Digest::MD5>
                  Can somebody help me please ?
                  • Dan RathbunD Offline
                    Dan Rathbun
                    These files do not belong in the "Plugins" dir. The should stay in the Ruby "lib" & platform dirs, and you should add those paths onto the $LOAD_PATH array.
                    These so files also need "digest.rb" and "digest/sha2.so" (at least in Ruby 1.8.6-p287,.. where "md5.rb" is no longer needed.)
                    I'm not here much anymore.
