    Stone/rock path
    2 Posts 2 Posters 1.2k Views 2 Watching
    • S
      Starlex
      Hello!
      Where I can get flat stone components to creating path, for example
      http://www.landschaft-ose.ru/images/dor3.jpg
      . At he 3D Warehouse there are only big rocks, not flat
      Thanks!
      • mitcorbM
        mitcorb
        You can create these yourself rather quickly in Sketchup
        Draw a rectangle on the ground.
        Draw an irregular outline of a flagstone and close the lines. Pushpull the resultant face up say 2.54 cm. Erase the rectangle, select the remaining geometry, right click, select make component, give it a name. Do this a number of times to create unique random flagstones.
        Also, edit the component and trace over one of the segments on the bottom of the figure if you want to close the bottom face of the stone.
