    New Toolbar button ?
    10 Posts 2 Posters 749 Views 2 Watching
    • P Offline
      peweuk
      I posted earlier about creating a new ruby for reporting.
      Ok - I've got that figured now, but for the next step I'd like to add a toolbar button to launch the script (rather than it being done from the plug-ins menu).
      Can anyone tell me if this is do-able - and if so, is there any information anywhere explaining how to do it??
      TIA
        Have you looked at the API docs: http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/toolbar.html
        The first example on that page shows how to add a toolbar with a button.
        • P Offline
          peweuk
          Thanks ThomThom.
          I have looked at this and got it working with my own icons and dialog, but can someone tell me what I need to enter in the cmd line to launch a ruby - for example called 'myruby.rb' which is in a plugin subdirectory called 'myruby'.
          toolbar = UI::Toolbar.new "Test"
          # This toolbar icon simply displays Hello World on the screen
          %(#FF0040)[cmd = UI::Command.new("Test") {
          UI.messagebox "Hello World"
          cmd.small_icon = "ToolPencilSmall.png"
          cmd.large_icon = "ToolPencilLarge.png"
          cmd.tooltip = "Test Toolbars"
          cmd.status_bar_text = "Testing the toolbars class"
          cmd.menu_text = "Test"
          toolbar = toolbar.add_item cmd
          toolbar.show
            You add that code to your 'myruby.rb' itself. Not as a separate script.
            Replace UI.messagebox "Hello World" with the method call to your script. The same command you used in your menu item.
            • P Offline
              peweuk
              Thanks Thomthom.
              Forgive my ignorance, but I am not a script writer and have simply cobbled together a couple of scripts by 'hacking' parts of other scripts together to suit my needs, and this particular task is a little bit beyond me at present.
              I assumed that you were referring to the part in my 'myruby.rb' where the command is added to the plug-ins menu - ie
              plugins_menu = UI.menu "Plugins"
              plugins_menu.add_item("Generate CSV") {
              dcomp_reporter2.generate_attributes_report("report.html", Sketchup.active_model.entities)
              I tried replacing the UI.messagebox "Hello World"with the third line of the above (which appears to be part that launches the script from the plugins menu), but this does not work.
              What have I misunderstood.
              TIA
                You have understood correctly. - think. from what I can see at least.
                do you get any errors in the console when it doesn't work?
                • P Offline
                  peweuk
                  This is what I have at the beginning of the script, the part between the toolbar mods is what I added to the original script - did I put it in the wrong place?
                  require 'sketchup.rb'
                  Monkeypatching the hash to allow the uniq function of array to work...
                  class Hash
                  def hash
                  to_a.hash
                  alias eql? ==
                  class DCompReporter2
                  #-----toolbar mod begins-----------
                  toolbar = UI::Toolbar.new "Reporter"
                  cmd = UI::Command.new("Reporter") {
                  cmd.small_icon = "dcreports/Excel16.png"
                  cmd.large_icon = "dcreports/Excel32.png"
                  cmd.tooltip = "Produce Report"
                  cmd.status_bar_text = "Produce Report"
                  cmd.menu_text = "Report"
                  toolbar.show
                  #-----------------------------toolbar mod ends------------
                  After that is the script which still works when loaded from the plugins menu.
                  I get no errors on screen when I start SU, and when I click the icon on the toolbar, nothing happens.
                  How do I check the console to see if there are any errors when I click the icon?
                  • P Offline
                    peweuk
                    Here are the errors shown in the console when I click the toolbar icon.
                    Error: #<NameError: undefined local variable or method dcomp_reporter2' for DCompReporter2:Class> C:/Program Files/Google/Google SketchUp 7/Plugins/DComponentReportercsv.rb:37 C:/Program Files/Google/Google SketchUp 7/Plugins/DComponentReportercsv.rb:36:in call'
                    • P Offline
                      peweuk
                      No worries - I fixed it 👍
                        Modifying Ruby and Sketchup base classes are a big no-no. Some other plugin might require the original behaviour.
                        Instead of modifying the existing - create your own class which inherit the HAsh class and modify that.
