Help Me Draw A Dome [TUTORIAL]
Hi Gaieus/Tig
Tig: Thanks for confirming the volume.
I have these SKP's and I'm trying to push it into Layout but it just wouldn't sit centred on my page.
Please can you guys help me to send both these SKP's to Layout. The SKP called Pieces have 10 items and each item will fit on a A4 page on a 1:1 scale. The red and blue blocks are grouped and sized in such a way that it should fit perfectly centred on an A4 page. I manage to send it to layout but it's either skew or if i get it straight then it's not centred.
The SKP Called Circle can fit on any size page as long as it's centred and also on a 1:1 scale.
If you can supply in PDF format, it would be appreciated but that's something I should be able to do.
Sorry, I know I'm being a bit lazy but I've been failing with this and I need to submit these drawings to my supplier urgently so he can cut accordingly.
By the way Gaieus, I plan to upgrade this weekend.
Regards
D0me
Hey Guys
Push came to shove and I managed to figure this out. As soon as I made the first guideline, I remembered during Gaieus lessons, he showed me how to use them and that's exactly what I did, used it to align each item and print it individually to PDF, all worked perfectly well.
Regards
D0me
Register LoginAdvertisement
