    Passing arguements
    6 Posts 3 Posters 343 Views 3 Watching
    • honoluludesktopH Offline
      honoluludesktop
      Can Class My_Tool have the following form? Class My_Tool(menu_selection). If not how can I pass menu_selection, that are outside the Class to it? Hope my question makes sense.
        class My_Tool
          def initialize(selection)
            # do something 'selection' is now a variable
        my_very_own_tool = My_Tool.new(menu_selection)
          honoluludesktop
          Thanks, Tom. Is this OK, and safe to use?
          Class My_IDX_PointTool
          	def initialize(menu_selection)
          		@sel = menu_selection
          	def program
          		#do somenting with menu_selection
          		puts @sel
            Yes. πŸ˜„ You got it!
            • Chris FullmerC Offline
              I use this also:
              class My_Class
              def option1(arg, arg2, etc)
              puts arg
              my_etc(etc)
              def option2(arg, arg2, etc)
              puts arg2
              my_etc(etc)
              def my_etc(etc)
              puts etc
              arg = Sketchup.active_model.selection
              arg2 = Sketchup.active_model
              etc = [1,2,3]
              tool_object = My_Class.new
              plugins_menu = UI.menu("Plugins")
              plugins_menu.add_item("Option 1") {Sketchup.active_model.select_tool(tool_object.option1(arg, arg2, etc))}
              plugins_menu.add_item("Option 2") {Sketchup.active_model.select_tool(tool_object.option2(arg, arg2, etc))}
              That is also a way to use the same tool object each time the tool gets called, instead of instantiating a new one each time. And I point diretly to a specific method within the class when I start the tool. It could also be done with a line like this:
              Sketchup.active_model.select_tool( My_Class.new.option1(arg,arg2,etc)
              See how that instantiantes a new tool object each time its run, but it also points directly to a method of the class.
              Hope that made sense,
              Chris
              All my Plugins I've written
                honoluludesktop
                Guys, thanks for the help. Chris, I will look very carefully at your example.
