    Mouse event or...
    3 Posts 2 Posters 273 Views 2 Watching
      bizello
      Yes, me again...😄 😄 😄
      I,ve seen plugins that after start wait for a lot of mouse clicks to insert a point (like clinetool) or a component (like component spray). How create this type of mouse event?
      I have a script that insert a hole on the wall from its base line. But every time I have to select the base line and activate the script. I want run the script and select the base line, the hole is inserted (already do this) and the system ask for next base line, and so on. This is a mouse event, right? How to do this? Is this happen in cclinetool, correct? And for these cases how is the better way to finalize the command? Right click, escape key or another action?
      A lot of questions you are saying, I know, but here is the best place to kill my doubts.
      Thanks.
      Sérgio
      P.S. I've searched on the web and I've opened some scripts to learn how do this, but also I'm trying to leave the programmer's begginer level, and need some explanations as the functions works.
      Sérgio A.Bizello
        You need to implement the Tool class: http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/tool.html
        In your plugins folder there is an Example folder - that has examples of how to build a Tool.
          Moved the thread to the Developer's forum. We have reorganized so that the Plugin section is only a list of plugins you can download and use. 🤓
