    SU to blender (+ small tutorial)
    34 Posts 14 Posters 9.2k Views 14 Watching
    • michaliszissiouM Offline
      michaliszissiou
      OK, blender 2.5 is Alpha 0, lets work with v2.49b. Lets keep v2.5 for rendering.
      Its a small tutorial here. Exporting from SUpro as .obj. Exporting textures too. When impoted to blender check for doubles. I didn't find any though. If models are already textured in SU, DO NOT convert triangles to quads, UV problem. You can edit UV textures however, you can even have texture painting, projected textures etc. Everything works just fine, just don't subdivide geometry (bad triangulated SU models here).
      Here's an old SU model:
      As you may noticed I'm checking faces so to look outside, that's really important. No blue faces, ok
      So in SUpro, export .obj like this:
      Importing .obj in blender 2.49b like this.
      Here's the model in blender. You can see on the right, all textures UVs etc have imported beautifully.
      I deleted cactus and added some blender trees BTW. Everything works like a charm
      A quick render ~2 min
        Very cool tut and neat result! 😎
        Can I translate your tut in French?
          michaliszissiou
          My pleasure Pilou.
            Thx! β˜€
            Done! 😎
            • EarthMoverE Offline
              EarthMover
              Michalis, does this mean that you will import into 2.49 first, then save as .blend file and open it in 2.5 for rendering? Just trying to understand the workflow. I can't wait until they are finished with 2.5. It is a real gem in the making...especially if it is still free!!
              Also where do you get your Blender trees?
              Content Creator at Skapeup
                michaliszissiou
                Yes Adam. You can save the v2.49b file and open it in 2.5 (much faster renderer). But you have to wait for a full functional 2.5.
                As for "if it is still free" read this one. It will always be a freeware app.
                http://www.blender.org/education-help/faq/gpl-for-artists/
                • EscapeArtistE Offline
                  EscapeArtist
                  This works well, I had to do this to get the collada import to work. Import with 2.49, save as .blend, re-open in 2.5. Didn't know the .OBJ import was broken too, thanks for the heads up.
                    michaliszissiou
                    An updated render, using blender particle system for dry grass. I have a lot more to learn...
                      Jakerlund
                      Anyone know how to run kt2obj in OS X?
                      There is a Unix version and since OS X is Unix based i thought it would be possible.
                      But my knowledge in terminal is πŸ‘Š
                      Any tips are welcome.
                        EscapeArtist
                        Jakerlund
                        Your question would be better answered in its own post.
                          Starling75
                          Hmm... Blender 2.57 can't import collada exported from SU8 ..?
                          http://www.starlingarch.cz
                            michaliszissiou
                            A tip.
                            Keep a blender 2.49b for this. For the moment. πŸ˜‰
                            The best way to export is the official obj format. But you need SU pro... what a shame for google. πŸ‘Ž
                              For SU free version use the Export obj + Material by TIG πŸ˜‰
                                michaliszissiou
                                Similar problems to collada pilou...
                                blender/ edit mode / w / remove doubles !!!???
                                • 2 / 2
