    Components packets
    3 Posts 3 Posters 1.3k Views 3 Watching
    • O
      outwest77
      Is there any way to download a huge component packet like they used to have on SU
      I did the new version and every time i want components it calls up online, if I cannot connect to the internet, I basically cannot use the program,
      Also the plants that I see, suck, they are not 20 percent of what I used to have access to,
      basically the new setup with the way you access the components is terrible, and the components available are not near as good of choices as the huge component packs they used to have
      any way to download those old component packs. Is there some place someone has stored them or would be willing to share them
      • numbthumbN
        numbthumb
        If you are referring to SU5 and SU6 components library, you can find them here
        http://sketchup.google.com/download/bonuspacks6.html
        http://www.giveawayoftheday.com/sketchup+5+component+library/
        (although I dont´t know if this could be considered a "huge pack")
        Comfortably numb...
        • K
          KXI System
          The way the Components dialog box works is that it actually looks inside a folder to see if any files there it can display.
          To get a better picture, here is what you have to do in a Windows computer:
          Computer>Hard drive(or where SU was installed)>Google> Google sketch up [your version]>Components
          Thats where SU stores its components, if you want an extra pack look at the guy above or wait until Google makes a v7. Personally I just put any models that I like into this folder.
          Some of you might not know is that now the dialog box actually links to the 3-D warehouse, so whatever you search in that search box there will come up the same in the warehouse dialog box. Simply its just a faster way to surf the warehouse without taking up so much space when you don't want it to.
          Yea its messed I know.
          Getting the perfect sig is hard...
          Google it!
