    [Plugin] YZ + X v1.0
    2 Posts 2 Posters 9.3k Views 2 Watching
    • Chris FullmerC
      This is from a request here:
      http://forums.sketchucation.com/viewtopic.php?f=323&t=24011
      This script is highly specialized, I don't recommend downloading and installing it unless you know you need it. Which you probably don't. πŸ˜„
      Description
      This script lets you pick 2 vertices. It then takes the YZ coordinates from the first vertex and the X coordinate from the 2nd vertex and use those 2 points to create a new point, and it adds a construction point in that location.
      Usage
      Plugins > Chris Fullmer Tools > YZ + X. Select the first point, then the 2nd. It will add a construction point. This plugin does not work right if the model axis has been altered. So reset the model axis first - sorry!
      Chris
      clf_yz_x.rb
      All my Plugins I've written
      • M
        Mael
        Thank you so much for creating this plugin for me! I was having no luck creating this plugin myself or finding a similar one on the web. You really have saved me a great deal of time, assuming this plugin works as intended 😜 I can't thank you enough!
        Nvm I found the problem. Thanks again πŸ˜„
