    Web Dialog and Data
    10 Posts 2 Posters 1.5k Views 2 Watching
    • B
      bizello
      Hi friends,
      I would like to create a html webdialog to send data (text, radio state, checkbox state, etc) as variables to ruby script. After that, I´ll work these variables and return results on other html as text only.
      Is it possible without javascript?
      Thanks.
      Sérgio Bizello
      Sérgio A.Bizello
      • thomthomT
        No. Ruby communicates back and forth with Webdialogs using JS. No way around that.
        Any particular reason you don't want to use JS?
        • thomthomT
          Or saying that... webdialog.get_element_value retrieves the value of input elements without any JS.
          • B
            bizello
            Well, I just wanted to use the least possible languages. If no possible, ok.
            Do you know a site where I can see and learn a simple code in JS to capture information from webdialog and show information on a webdialog?
            Thanks TT
            Sérgio A.Bizello
            • B
              bizello
              Ok... I'll see how it works, but if you have some example, send me if you can. I'll be grateful for this help too.
              Thanks again TT.
              SérgioBizello
              Sérgio A.Bizello
              • thomthomT
                http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/webdialog.html#get_element_value
                The example has been mangled though. should say:
                # In Ruby code;
                dialog.get_element_value("myTextInput")
                # In webdialog's HTML;
                # <input id="myTextInput" value="hello" type="text">
                • B
                  bizello
                  > # In Ruby code;
                  How is the data transmission? After clicking the OK or closing the dialog box? I'm sorry the basic question but, I'm a begginer and I doubt it. If the webdialog has checkbox, radio, etc. This works with these types? Or have any exception?
                  Sérgio A.Bizello
                  • thomthomT
                    .get_element_value is a method that immediately returns the value of the input element.
                    myVariable = dialog.get_element_value("myTextInput") puts myVariable
                    That snippet will take the value of myTextInput and assign it to the variable myVariable and then prints it to the Ruby Console.
                    • thomthomT
                      Should work for checkboxes and radio boxes. they are also INPUT type HTML elements. Not sure about SELECT and TEXTAREA fields etc. Haven't tried them.
                      • thomthomT
                        Moved the thread to the Developer's forum. We have reorganized so that the Plugin section is only a list of plugins you can download and use. 🤓
